ford fiesta 1998 rear brake adjustment
Old 31-01-2006, 05:45 AM
sided4ag
sided4ag's Avatar
Default ford fiesta 1998 rear brake adjustment
Do you need to take of the wheel bearing to adjust the hand brake.And if so what must you torque the bearings.
Old 31-01-2006, 07:40 PM
vyper developments
vyper developments's Avatar
hi,
to adjust the rear brakes properly you will need to remove the rear drums which house the bearings. The correct procedure according to ford is to remove the stub axle from behind and drum complete so as not to disturb the bearings, in reality very few people do it the proper way and just undo the centre nut and pull of the drum. Dont know torque figure to do it up but good and tight is usually ok.
Remember to back off the handbrake cable adjuster first though under the handbrake lever gaiter. Also check the inner faces of the drums and remove any ridges otherwise this will prevent the brakes being adjusted up nice and snug.
Mike.
Old 31-01-2006, 07:46 PM
cocaina_xr2i
wrench it all
cocaina_xr2i's Avatar
if you say so m8 but even in the haynes manual says that the hand brake ajustment is done by the nut in the hand brake cable but if what your are saying is a better option would you please explain better so I can folow the same process as yo thanks
Old 01-02-2006, 10:16 AM
sided4ag
sided4ag's Avatar
thanks i will do so
Botts
13-08-2015 04:16 PM
Bosch
04-08-2015 05:14 PM
Quick Reply: ford fiesta 1998 rear brake adjustment
