Cosworth T5 5th gear.
Old 29-01-2006, 01:29 AM
BMEP
BMEP's Avatar
Default Cosworth T5 5th gear.
Does anyone know if the 5th gear from a Cosworth Borg Warner T5 is still available to buy new???? If so, who sells them????
Old 29-01-2006, 10:09 AM
pee vee
pee vee's Avatar
I reckon Gearbox man from this site will be able to help you out
mate,
If not then burton power list them in their catalog
Old 29-01-2006, 10:36 AM
BMEP
BMEP's Avatar
Thanks pee vee , I have tried Burtons as well as a few other well known companies over there and no one seems to have one. Mike Rainbird generously tried all his contacts including Bernie from CTS to no avail
If I’m not mistaken I may have sent Gear Box man an email threw his web site. That is if we are talking about the same person.
Old 29-01-2006, 07:43 PM
foreigneRS
Testing the future
foreigneRS's Avatar
i have been informed by bernie (gearboxman / CTS) that they are no longer available. i will be rebuilding my t5 in the next couple of weeks and will have to be careful when removing it.
on this topic, someone else said that they could be bought from USA, but not sure if it's true. i hope i don't have to find out.
https://passionford.com/forum/viewtopic.php?t=144107
Old 29-01-2006, 09:16 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Try Quaife, i think they do a standard replacement.
http://www.quaife.co.uk/catalogue/page31.htm
Old 30-01-2006, 11:13 AM
BMEP
BMEP's Avatar
Thanks for the replies guys I have tried a few companies in the States and the replies I got were that the GM T5’s ran 27splines and the Ford T5’s ran 28 splines where as the Cossie’s run 23 splines.
There has been talk of a gear company here that “may” take on the job of manufacturing 100 gears, this is not someone I have dealt with personally so cannot confirm for shore, needless to say that I’m interested if anything comes of it.
In a worst case scenario it does seem that Quaife does seem to have a replacement
Old 31-01-2006, 07:39 AM
2wd
2wd's Avatar
Default Re: Cosworth T5 5th gear.
Hi..I just bought a complete rebuild kit + 5th gear and a couple other gear wheels from http://www.5speeds.com and prices and service are super too
Old 31-01-2006, 08:30 AM
foreigneRS
Testing the future
foreigneRS's Avatar
good find tom
Old 01-02-2006, 07:23 AM
BMEP
BMEP's Avatar
Thanks for all the replies guys
2wd, that site is a good find, you must have got luck with your 5th gear thought, cos I e-mailed them and a person called Paul replied back saying that the 5th gears are discontinued
It might be worth checking to make shore the correct item was sent to you. It should have 23 splines on the ID and 33 teeth on the OD. The part number should be 1352-070034.
Old 01-02-2006, 07:46 AM
2wd
2wd's Avatar
Oh they are ok...splines and P.number where fine and both boxes are working perfect, no prob there
I'm sorry to hear that they are discontinued... but I hope that you will find another 5th gear wheel...
Old 01-02-2006, 07:51 AM
BMEP
BMEP's Avatar
2wd,
You got very lucky mate How long ago did you buy the 5th gear from them?
Old 01-02-2006, 08:16 AM
2wd
2wd's Avatar
2wd,
hmmm...more that a year ....just got it build and tried last summer..
Old 22-02-2006, 01:11 PM
crf450r
crf450r's Avatar
theres a guy on ebay (UK) now selling rebuild kits for T5's, He also advertises new 5th gear sets! search for cosworth gearbox or something on ebay .co.uk
Old 23-02-2006, 08:03 AM
foreigneRS
Testing the future
foreigneRS's Avatar
broke mine at the weekend trying to remove it
picked up another box for Ł50 thanks to costina, so will mix and match the best parts of 2 gearboxes to make 1 (keeping gear pairs matched of course)
Old 23-02-2006, 08:49 AM
BMEP
BMEP's Avatar
Bummer
You will have to be careful not to damage the 5th gear when removing it from the ‘box you just bought
Old 23-02-2006, 07:18 PM
foreigneRS
Testing the future
foreigneRS's Avatar
exactly. got the technique down now though, and the special puller made up. it's just those first few millimetres that are tricky, as there is very little gap behind the gear to get a puller on. and if you only use a small one, you are putting all the force through the teeth, rather than the flat of the rear of the gear
Old 23-02-2006, 07:45 PM
2wd
2wd's Avatar
Any chance you got a couple of good pic's of the "special" puller
Old 24-02-2006, 07:39 AM
foreigneRS
Testing the future
foreigneRS's Avatar
i'll post some up later. basically, it's just a normal 3 leg puller with the 'teeth' ground down thin, and the short legs replaced by equal length (very important) long legs
Old 24-02-2006, 07:43 AM
2wd
2wd's Avatar
ok ..looking forward to see
Old 24-02-2006, 01:43 PM
foreigneRS
Testing the future
foreigneRS's Avatar
2wd
there you go mate
Old 24-02-2006, 02:08 PM
2wd
2wd's Avatar
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
fordjames
Ford Focus Diesel
03-09-2015 10:20 PM
Quick Reply: Cosworth T5 5th gear.
