Removing recirc DV
Old 14-12-2005, 12:32 PM
Cosworth-PT
Cosworth-PT's Avatar
Default Removing recirc DV
I want to do some tests without the (original) recirculating dv. Could anyone tell me how to do it?
besides the plug at it's place, what to do with it's tubes? the one that comes from engine to dv, and the other one that comes from the actuator to amal?
Old 14-12-2005, 01:08 PM
XR4Timan
XR4Timan's Avatar
You can remove the recirc DV by just plugging the spout on the IC. You can leave the other port open (on the air cleaner hose from the turbo inlet).
The thin manifold vacuum hose to the DV just needs to be plugged. Some people just use a 'screw' they have lying around.
As far as the hose to the actuator to the amal valve - my recommendation is to leave it alone. Basically it's a computer-controlled "bleed valve". When the ECU gives the signal, it will allow air to bypass the wastgate actuator, tricking the wastegate by increasing the boost above what the wastegate is set to. If you don't understand how the concept works, leave it well alone.
Old 14-12-2005, 01:28 PM
Cosworth-PT
Thanks. I said about the amal-actuator hose but it has nothing to do with what I want. tks for remembering me
Old 14-12-2005, 01:48 PM
Mad_Ad_300bhp
Mad_Ad_300bhp's Avatar
just plug the vac line mate, no need to pull off the recirc to the air filter
Old 14-12-2005, 01:50 PM
Cosworth-PT
do you mean: to leave the recirc at it's place and just plug the vac line?
Old 14-12-2005, 02:00 PM
XR4Timan
XR4Timan's Avatar
Yes. You can do that too. However if the diaphram of the recirc DV is bad, you'd still want to plug the port.
Mad_Ad_300bhp
yeh just take off the little vac pipe and put a bolt in it. as the valve will be shut theres no need to block the bigger recirc pipe off.
Old 14-12-2005, 02:13 PM
Cosworth-PT
thanks. will give it a try.
Old 14-12-2005, 04:11 PM
Mad_Ad_300bhp
yeh i suppose if you are doing it too if the diaphram is fookered then try it with that blocked aswell( get a broom handle!)
Old 14-12-2005, 06:09 PM
Cosworth-PT
Thanks.
This is strange: with or without recirc DV, every sound (chatter) is just the same, does this means that DV is broken? I have this 2wd since May and allways made the same sounds
Old 15-12-2005, 06:22 AM
XR4Timan
XR4Timan's Avatar
I would check the vacuum line. Put your finger on it when the engine is running. Better still, replace it with another DV and check it out.
boeb
09-01-2020 05:11 AM
Orion_Gav
29-09-2015 04:50 PM
Quick Reply: Removing recirc DV
