clutch cable
Old 16-11-2005, 07:35 PM
nice_head
nice_head's Avatar
Default clutch cable
Theres something wiv my cossie and clutch cables, ive snapped 3 cables in the last 4 months and i reckon the fourth is on its way coz the pedal is getting stiffer again..
Why does it keep on snapping?
Old 16-11-2005, 10:56 PM
vyper developments
vyper developments's Avatar
Hi, are you running a standard cutch or a paddle type?
Mike.
Old 17-11-2005, 12:05 AM
jon@work
jon@work's Avatar
check the routing near the turbo - are you melting them ?
Old 17-11-2005, 06:23 AM
filthyrichie
filthyrichie's Avatar
have u got it routed right at the pedal ..sometimes they cut through on the bracket by the ratchet and pawl unit
Old 17-11-2005, 04:23 PM
cossiegreg1
cossiegreg1's Avatar
im the same as you pal, i snapped loads and what had happened was i was snapping them where it goes through the bulk head,n.r ratchet, the cable isnt sitting right and its slowly wearing through them.now i have to make sure its seated correctly and just keep checking.some 1 told me that this is a fault on sapphires.I dont know how true it is though.if your cable is not snapping here it could be your turbo melting it! hope you sort it
Old 17-11-2005, 06:22 PM
nice_head
nice_head's Avatar
she's running a pedal clutch, the funny thing is, is that engine advantages fitted my a new clutch back in july and a new cable and when i ask bout the cable snapping, they said it might be something to do wiv my clutch plate or something..
Old 20-11-2005, 10:22 AM
twitchyrear
twitchyrear's Avatar
id get on to ea and get them to sort it,especially since its only happened since they fitted your clutch
Old 20-11-2005, 11:04 AM
YBP
YBP's Avatar
The clutchcable doesn´t seem to cope with the extra tension made by uprated clutch plates (not sure what i is called in english, but a direct translation from norwegian would be "pressure plate" )
Mine always snaps by the pedal, and I think it´s because it has the sharpest bend there. (around the plastic adjustment sprocket(?) )
Old 20-11-2005, 11:49 AM
nice_head
nice_head's Avatar
yeah thats where mine always snaps to..
Old 20-11-2005, 06:29 PM
Mr C
Mr C's Avatar
mine has snapp a couple of times too since ive owned it, by the ratchet again, and my mates sapphire snapped his last week... by the ratchet. Goode do a replacement cable doing away with the ratchet and pawl auto adjustment, but it costly at £175 for manual adjustment.
Anybody used one yet? Could always go Hydraulic?!?!?! ££££s
Old 22-11-2005, 04:49 PM
bazpro
bazpro's Avatar
i melted 1 of mine next to the turbo so put heat wrap around it and was fine.
mark94
10-10-2023 06:52 PM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
muz
30-09-2015 08:29 AM
Quick Reply: clutch cable
