zvh conversion what parts do i need ??
Old 18-08-2005, 11:30 PM
RSTEVE
RSTEVE's Avatar
Default zvh conversion what parts do i need ??
time for a bit more torque and power
need a full list of bits needed for a 2.1 zvh conversion currently running mk3 cab with s1 rst engine non efi. stage 2 turbo pace intercooler, magnex, k&n 285t cam etc
got some calibra turbo parts avalible so would like to use that so can use those pistons
Old 19-08-2005, 04:14 PM
Badman38
Badman38's Avatar
Default Re: zvh conversion what parts do i need ??
cvh water pump & conversion plate.
non Stretch cvh head bolts torqued to 80Ib/ft.
1300 cvh cambelt tensioner.
1.8 zetec oil pump,sump,oil pickup and strainer.
felpro head gasket ( Optional) or 2.0 zetec but cvh head will need welding up to get a good seal.
cvh flywheel with the holes enlarged to 11mm.
1.8 dipstick tube
pistons 85mm 2.0L on a low mileage block or 86mm 2.1L
arp conrod bolts.
Old 19-08-2005, 06:31 PM
Turbo-T34
Turbo-T34's Avatar
Are there any tuners that do this engine build, and all you provide is a zetec engine (1.8 or 2.0)?
Old 19-08-2005, 06:37 PM
Davey8oy
Davey8oy's Avatar
Turbo-T34,
yeah mate ian howell! he owns fiesta frenzy aka area six! he s the daddy at zvh and zetec turbos!
Old 19-08-2005, 11:24 PM
gavintwopies
gavintwopies's Avatar
Got some calibra turbo parts avalible so would like to use that so can use those pistons
The calibra turbo pistons work better in the zetec turbo engine as the compression would be far to low if they were fitted to the zvh engine what you need is the c20xe pistons fitted to the red top astra gte, they are available for around the £160 figure for a set of 4 .
Also i have a tendency to go for 150mm long m10 caphead bolts (rated 12.9)rather than non stretch cvh ones its just that you dont get that much engagement if you use the shorter cvh bolts and could strip the threads out of the block when torquing them down.
for more info on building you own go to jim hernes site.......................
http://www.quantums.info/zvh.htm
hes a top boy
Old 20-08-2005, 12:03 AM
Johnny Knoxville
Johnny Knoxville's Avatar
My mate sells a kit to do the conversion
Old 20-08-2005, 11:35 AM
RSTEVE
RSTEVE's Avatar
spoke to mad for it they will sell a complete 2.0 zetec bottom end converted for a zvh conversion including there conversion kit delivered to the door for approx £650-£750, the pistons are standard though so only use 1 bar of boost.
got some bit on ebay as well search "zvh"
Old 20-08-2005, 11:40 AM
RSTEVE
RSTEVE's Avatar
how much and what does the kit consist of
Old 20-08-2005, 11:52 AM
RSTEVE
RSTEVE's Avatar
hes a top boy
do i just need the pistons and fit them to are the bits that attach them on the zetec (called conrod ??? ) sorry if that a stupid question but not to good with a spanner
Old 20-08-2005, 03:08 PM
Turbo-T34
Turbo-T34's Avatar
When it comes to engine building, i'm a curious fellow, but i have a habbit of messing things up, so i would rather leave it to a pro.
Is there a website for fiesta frenzy / area six Davey8oy?
Old 20-08-2005, 04:02 PM
Johnny Knoxville
I don't know but his E-mail address is freakpower300@yahoo.co.uk just ask him and he'll tell you
Old 20-08-2005, 05:09 PM
RSTEVE
RSTEVE's Avatar
check fast ford or performance ford for fiesta frenzy for the website and give mad for it a ring see what they can do for you.
Old 21-08-2005, 01:39 AM
Red16
Red16's Avatar
hes a top boy
i assume the vauxhall XE pistons need the same modifications as the Calibra Turbo pistons to be fitted to the zetec rods. in which case the little end of the zetec con rod needs to be machined out to allow the larger gudgeon pin of the vauxhall piston to fit.
Old 21-08-2005, 11:04 AM
jesterx9x
jesterx9x's Avatar
gavintwopies is absolutely correct in what he has said about usine the xe pistons and yes they do need to be machined on either face and the little ends made bigger to accomodate the pins to fit the zvh conrods - also needs 4 holes drilled in piston for the oil feed - however gavin does have milling machine and can build you the zvh bottom end as he has done mine - im sure if u flurttered yr eyes a little and asked him he could do it cheap for you - worked for me lol
mk1turboestate
02-12-2015 08:31 PM
IainRS1700T
25-09-2015 06:44 AM
davidfordrs
23-09-2015 02:26 PM
jonnyenglish
21-09-2015 07:31 AM
davidfordrs
21-09-2015 04:23 AM
Quick Reply: zvh conversion what parts do i need ??
