Ford Range This section is for other models in the Ford range.
Escort Van ride height question.....
Old 12-03-2013, 10:55 PM
perry3188
perry3188's Avatar
Default Escort Van ride height question.....
This is a little hard to explain so bear with me...
Im going to lower my escort van by doing the axle on top of the leafs trick. I will have a set of 195/50-15's on the van and I DON'T want to have to roll the arches. I want all the wheels to be able to be seen through the arches... not "tucked in" if you know what I mean? I will lower the rear then raise it up a little bit on blocks if I need to to get the right height then get the correct springs to match the front.
I hear doing the axle trick will take it down about 80mm and I'm assuming that will be too much for the 15" wheels? (correct me?)
Can anyone share their vast experience with me and tell me what size springs I will need for the front? (or how many coils to cut... did I say that out loud???)
Also...I heard (read) a myth that Peugeot rear shocks will fit an escort van. Can anyone tell me if this is true?
Old 12-03-2013, 11:55 PM
s1 turbo stu
s1 turbo stu's Avatar
Ill look at mine tomorrow wot year van you got...... what mk ??????????
Old 13-03-2013, 01:32 PM
perry3188
perry3188's Avatar
Cheers it's a mk6 1998
Old 13-03-2013, 05:31 PM
escortmk3rwd
escortmk3rwd's Avatar
ive done mk4 conversion loads cut spring bedding plates off weld them on bottom of axle and i use vauxhall combo shockers diesel uprated ones and ive used mk1 escort before but combo cheaper and easier to get hold of i had 2 inch lowering blocks on mine also
Old 13-03-2013, 06:11 PM
Minirotty
Lucifer II - 666
Minirotty's Avatar
To lower the arse of a MK6 1998 you'll need to do a bit of fabricating to get it spot on.
Axle flip is only part of it, as once that's done, it drops about 90mm and far to low for most of us.
To bring it back up, where the leaf springs mount to the rear of the van, I made longer by 50mm brakets, to raise the van back up.
Heres how she sits with 17's on.
Old 14-03-2013, 11:37 AM
perry3188
perry3188's Avatar
Thanks for the info. I read your thread on the rs2000 conversion. You've done a nice job. I like how it was supposed to be a low cost pikey adventure and you've managed to do a proper job!
Old 14-03-2013, 08:42 PM
Minirotty
Lucifer II - 666
Minirotty's Avatar
Haha cheers, she is a pikey build though in the aspect the van was built from my spares pile lol
Old 12-04-2013, 01:05 AM
Dan j
Van modder
Dan j's Avatar
My experience with lowering the mk6 van
This setup is achieved by doing the 3 leaf mod. . You do the axle flip as usual..I also kept my original axle brackets in place and bought some escort mk2 saddle brackets and buy some escort mk2 u bolts which are longer. These are available on ebay.. so you get another pair of van top leaf springs and cut them down so they are 1" longer each end than the bottom leaf spring.. fashion a longer locating bolt and put them all together which should look like this. .
Will be doing the same with my next van.
Old 04-05-2013, 12:14 PM
simon513
simon513's Avatar
Ha there, like the work, I'm just about to start my van project with intention of lowering it, the axle flip seems the obvious choice, but I'm a bit unsure what to do about the brake bias, with the van being lowered, will this affect the bias?
Old 04-05-2013, 04:08 PM
Dan j
Van modder
Dan j's Avatar
The load bias is designed for when extra weight is on the back more braking force is applied. . So lowering the rear will give the same effect as a weighted up van. Theres more of a chance of the rear brakes locking up under heavy breaking and no weight in the rear. As I say there is more chance but I know a few people who have done the job and removed bias with no issues.
Old 04-05-2013, 05:12 PM
simon513
simon513's Avatar
Is there anyway I can adjust the bias to compensate for the axle flip?
Old 04-05-2013, 05:23 PM
Dan j
Van modder
Dan j's Avatar
There is but I have not done it so cannot give advise
Old 04-05-2013, 05:27 PM
simon513
simon513's Avatar
OK no probs, I'm sure someone out there will know.
Old 05-05-2013, 08:30 AM
cossieboy599
cossieboy599's Avatar
yer in my van when i lowered it i removed it and put a after market brake bias in and set it to how i wanted it to brake
Old 05-05-2013, 09:14 AM
simon513
simon513's Avatar
where would i find an after market brake bias?
also im looking to find anyone on here that has turned there rear doors into a single door with top hinge.
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
Bighandsuk
02-09-2015 05:23 PM
Marc sierra
12
30-08-2015 10:38 AM
A.t.p
15-08-2015 11:37 AM
Quick Reply: Escort Van ride height question.....
