st170 retarding timing??
Old 08-03-2013, 09:17 PM
The Underdog
you cant fix stupid
The Underdog's Avatar
Default st170 retarding timing??
Has anyone here not used a vernier on the exhaust cam and slackend the stock pulley and retarded 6 degrees this way.
im tempted to do it but looking for some advice on it first.
thanks in advance
Old 08-03-2013, 09:52 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
its possible this way and has the same effect, but with a vernier they are marked with the degree to adjust adv/ret
you would have to know bang on where 6degrees was on the std pulley, then dowell the pulley as they move when you torque them up
Old 08-03-2013, 09:58 PM
The Underdog
you cant fix stupid
thank you.
i was thinking of fitting the belt as stock then remove the straight bar that locks the rear of the cams and i would twist the cam. im thinking of making or having made a 5mm bar with a 6 degree angle in one end to align the exaust cam if that makes sense.
Old 08-03-2013, 10:05 PM
Cossie Sean
erm, in all fairness
i would be inclined to mark the pulley, and even drill a small pilot hole when it is marked up at 6degrees
then put the cam and pulley in a vice (gently mind!) and tap a roll pin into it
bit not all the way through as it`ll piss oil everywhere!
Old 08-03-2013, 10:49 PM
The Underdog
you cant fix stupid
if the pulleys as standard are just held by bolt then i just thought i could put thread lock on bolt and re tighten back in after i turn the cam -6deg. iv never done a belt on a zetec or any other similar engine(last was cvh and 8v vaux a long time back) so iv plenty to learn but im willing to try most things if it will work.
im a carpenter so have some knowledge on working with angled degrees and have some ideas on how i can make up devices to adjust fairly accurately.
its just the cost of the pulley that puts me off. for a start they come in pairs and cheapest ive found is £120
if doing it diy is too risky for the reward then i may re think it though??
Palethorpe01
18-08-2015 06:09 AM
Rickyrustyfox
13-08-2015 01:11 PM
Quick Reply: st170 retarding timing??
