Wiring spot lights rs1600i
Old 10-10-2012, 06:33 AM
FordRSmania
FordRSmania
FordRSmania's Avatar
Lightbulb Wiring spot lights rs1600i
Anybody who nows how the original wiring runs for spot ligths and fog lights of escort mk3 RS1600i
First need some help with wiring loop for the spot lights. I found the connector for spotlights but where fore is the white one and the black one.
It connects to a relay the yellow one and there is a white cable which connect to number 87 the red/white one connect to nr 86
nr 30 should be for 12V+ and nr 85 is for mass -/-
Old 10-10-2012, 06:49 AM
FordRSmania
FordRSmania
and some random pictures, first of wiring loom for fog or spots??
pictures of yellow relay which came from connector
and a scheme for connecting fogs
Old 14-10-2012, 12:30 PM
xr3man
xr3man's Avatar
a silly quastion but i take it the looms off the car? when loom is back in. the spot light loom connector is behind water header tank, and fog light is by coil or where coil is on any other mk3, apart from rs16i and also relays in fuse box.
if wiring loom is off a rs or xr then all parts of loom are there
Old 14-10-2012, 04:04 PM
TommysKeeper
TommysKeeper's Avatar
When I had these fitted to my S1 early in it's life this came as a kit from Ford - Lights, loom, relay with fuse holder on top and even the correct matching switch. One wire direct to battery positive battery terminal and one to any earthing point.
Kam B
24-09-2015 10:40 AM
bigryrs
07-09-2015 06:45 PM
fuzzy
04-09-2015 10:11 PM
hopper350
04-09-2015 12:53 AM
turbowag
03-09-2015 08:07 AM
Quick Reply: Wiring spot lights rs1600i
