Focus st 2006 bonnet won't open??
Old 10-06-2012, 01:03 PM
gregors
gregors's Avatar
Default Focus st 2006 bonnet won't open??
Hello,
Went to have the aircon recharged and the bonnet won't open? Key just clicks in the lock sometimes other times it just turns and don't make any noise?
Any ideas on how to get it open?
Old 10-06-2012, 01:05 PM
Carlos-Titx
Carlos-Titx's Avatar
Probably by rippin the grill out and pulling on te cable to open it.
Old 10-06-2012, 01:10 PM
gregors
gregors's Avatar
The cable runs from the key behind the badge to a white cylinder?pulling it doesn't do anything?
Old 10-06-2012, 01:53 PM
liam20
liam20's Avatar
have you tryed pushing the key in hard they are very **** and do break only other way is to look through the grill follow the cable and you will see white cylinder using long pillers pull off the rubber boot then with a long screw driver push it into the cylinder and turn the key it should work.
Old 10-06-2012, 02:19 PM
Carlos-Titx
Is it a twisting motion on te cable instead of pulling? You twist/turn the key and don't pull a cable.
Old 10-06-2012, 02:22 PM
liam20
liam20's Avatar
yer you twist it one way to relese the bonet then the other way to open the lock
Old 10-06-2012, 03:31 PM
gregors
gregors's Avatar
Iv exposed the white bit, tried turning it with a screw driver with no luck, perhaps I'm not doing it right? There is quite a lot of movement in it.
Old 10-06-2012, 03:44 PM
liam20
liam20's Avatar
Use the screwdriver to apply pressure and then turn it with the key
Old 10-06-2012, 03:54 PM
RichieST
RichieST's Avatar
As above, pull the rubber grommet out with long nose pliers, then push the other end of the cable bit into the lock mechanism with a long screwdriver while turning the key. Very common on the mk2 focus, they are a shit design!
Old 10-06-2012, 09:11 PM
gregors
gregors's Avatar
Very poor design, thanks for your replies, I will give it another crack tomorrow
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
hopper350
04-09-2015 12:53 AM
Jerry Ryan
02-09-2015 08:02 PM
Quick Reply: Focus st 2006 bonnet won't open??
