Cossie Fuel pressure check... and a problem
Old 05-05-2012, 06:08 PM
Mungus
Mungus's Avatar
Default Cossie Fuel pressure check... and a problem
OK so im still going through the car bit by bit before I make the trip to NMS....
Today I linked in a fuel pressure guage before the regulator .... took the top pipe off.....reading under 1 bar
It did fluctuate a touch when the top pipe was reconnected which as I have read is expected. So went about adjusting the regulator to achieve the 3.5 bar it should be......could not get any increase in the pressure reading although could drop it however until it shut the supply completely, stalling the car.
So im thinking....
1. Blocked fuel filter?
2. Knackered regulator?
All advise appriciated.
Huw
Old 05-05-2012, 08:06 PM
rs2klee
K***LMT
rs2klee's Avatar
fuel pump!
Old 05-05-2012, 08:17 PM
Mungus
Mungus's Avatar
Originally Posted by rs2klee
fuel pump!
As it goes I was just about to edit my first ... thinking...
FUEL PUMP?!!?!
Prickly_buzz
25-08-2015 11:33 AM
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
Bailes1992
16-08-2015 07:14 PM
Zoggon
10-08-2015 10:39 AM
Quick Reply: Cossie Fuel pressure check... and a problem
