2wd Coolant hose Routing?
Old 16-04-2012, 02:27 PM
RSDog
RSDog's Avatar
Default 2wd Coolant hose Routing?
Does it matter which way round the coolant hoses are fitted on the oil filter heat exchanger? Also does it matter which way round the heater hoses are fitted to the bulkhead?
Old 16-04-2012, 05:07 PM
BRAMMER
BRAMMER's Avatar
If you buy a kit the pipes dictate where they should fit
As far as i'm aware when doing mine with a kit from AS
Looking at the oil modine the
left pipe - back of head (next to blue sensor)
right pipe - bottom pipe on bulkhead
top pipe on bulkhead - metal pipe that runs along the head
Old 16-04-2012, 06:31 PM
RSDog
RSDog's Avatar
Thanks for reply. The kit i have bought is telling me exactly what you've said and the reason i asked is that the hoses i took off were the opposite way. Maybe the previous owner fitted them the wrong way when he replaced the engine after painting the car
Old 16-04-2012, 07:11 PM
BRAMMER
BRAMMER's Avatar
It's a good chance, not sure if theirs a correct way round on the modine - but go with what you have
Old 01-05-2012, 02:32 PM
emilegarage
emilegarage's Avatar
I have converted a 2wd to a 4wd with a/c. Can someone please assist how to fit the water pipe from water pump onwards. thanks
emile
Fudgey
21
30-09-2015 06:19 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: 2wd Coolant hose Routing?
