Ford CVH engine in Puma - Project
Old 09-04-2012, 03:12 PM
barrymacpuma
barrymacpuma's Avatar
Default Ford CVH engine in Puma - Project
Hi guys, new to the forum.
Been looking about for a while for information on the CVH turbo engine and found some info. but need a bit more help if possible.
Have CVH turbo engine now installed in engine bay, but looking for info. on wiring the ECUs. I have the loom from the previous owner and also the original puma loom and ecu, but need to sort out the wiring to get the beast running.....
Has anyone done this conversion before? Heeeelllllp!...
Cheers guys - Baz.
Old 09-04-2012, 04:12 PM
rsfido_1989
rsfido_1989's Avatar
Pics please
Old 09-04-2012, 04:30 PM
Is it using Efi or mfi injection.
Old 09-04-2012, 05:47 PM
barrymacpuma
its mfi.
Old 09-04-2012, 07:25 PM
barrymacpuma
this is where ma projects at.
the rs turbo engine is in with custom r.h mount.conected to fiesta 1.8d gearbox and puma shafts.had to make a mount for r.h shaft on block.
cooling. rst rad and inter cooler fitted into moded puma rad cradel
fueling is m.f.i. I have mounted the unit just above the gearbox.
need help with..
wiren loom.
clutch to use. with internal slave.
power steering.
anything.
Old 09-04-2012, 07:36 PM
Pudnpepsi
Fix or repair daily....
Pudnpepsi's Avatar
ditch the MFi and go Efi. much easier! and more reilable!
Old 09-04-2012, 07:38 PM
1.9 xr2 on 40's
st170 breaking
1.9 xr2 on 40's's Avatar
fuck off the mfi and get efi, loads easier, the loom with almost plug and play (both are engine looms and you can replug etc your into the cars)
everything else is frst tank and pump, managment from frst and turbo can be t3 with the rad is nudged, much better all round with efi
beware bleeding the clutch, any air will fuck the slave and its a sod to change again huh
Old 09-04-2012, 07:49 PM
Pudnpepsi
Pudnpepsi's Avatar
^^^^ what he said. nuff said.
Old 09-04-2012, 07:54 PM
barrymacpuma
m.f.i to efi wits needed
Old 09-04-2012, 07:59 PM
Pudnpepsi
Pudnpepsi's Avatar
Efi head
Efi flywheel and block adapting for CPS
Efi inlet
Efi ecu and loom
Map sensor and co pot
Charge carrier
check your block. if its a 89 onward, it will most likely have a CPS hole already.
hope this helps
Old 09-04-2012, 09:19 PM
barrymacpuma
is mfi that bad.
Old 09-04-2012, 09:25 PM
barrymacpuma
did any of the cvh engines come with power steering.
Old 09-04-2012, 09:26 PM
1.9 xr2 on 40's
st170 breaking
Originally Posted by barrymacpuma
is mfi that bad.
its just sooooo much hassle
meterhead and all its crap ecu's etc and all those wires
an efi job can easily be done ina day and look factory
an mfi job will always look like a rats nest and have problems
you can do it many ways
i would always build up a zvh because even the cheap throw together ones are good on power and better than an old cvh
1.8 zetec bottom end with a cvh efi head + zvh kit
t3 turbo
frst managment
then the usual cooler, rad, pipe etc
all done for under 500 quid and you alreayd have teh box etc that will be fine
theres the same amount of work to fit wether its cvh or zvh but a little more work on a cheaper engine
you can still use all your oil feed etc from the mfi
Old 10-04-2012, 12:02 PM
barrymacpuma
thanks that put a spanner in the works
Old 10-04-2012, 12:17 PM
luke19790_3
luke19790_3's Avatar
you can use your head but you will need a adapter for the efi inlet.
Old 10-04-2012, 09:29 PM
barrymacpuma
too far into this project to go zvh maybe next time.
everything is in engine bay. layed out the same as the erst.
I got a running escort rst 90spec.
am hopen to use erst ecu.s wiren loom to run evary thing under bonnet.
puma ecu to run everything else
can you tel me if puma petrol tank. will fuel my mfi.
Old 10-04-2012, 09:32 PM
GVK.
GVK.'s Avatar
MFI fuel delivery pressure is about 5bar, your intank pump on the Puma 3 bar, so no.
Old 11-04-2012, 08:21 PM
barrymacpuma
Thanks for that. but i was hopen to use puma tank with pump removed
and have erst fuel pump mounted where the fuel filter was.
Old 11-04-2012, 08:29 PM
1.9 xr2 on 40's
st170 breaking
dude theres a fair bit going wrong here
i think you can use an escos or frst fuel pump being 'in-tank' pumps (frst pump housings have 'turbo' on a sticker on them)
an erst fuel pump pushes and doesnt suck so you cant mount it above the fuel level so i think puma fuel filters sit infront and above fuel tank/level
Old 11-04-2012, 08:32 PM
1.9 xr2 on 40's
st170 breaking
my advise has to be sell the lot and start over im afraid
if you engine is 90 spec you will have a hole in the block going thru to the flywheel
which helps as you can fit an efi flywheel and cps (in the hole) and use your bottom end but by the time you do taht you will put about Ł50 into a headset and bolts that could have bought you a zetec bottom end then you will still need an efi head unless you want to spend about than the cost of an efi head on adapters (which could mean the inlet hits things)
Old 11-04-2012, 09:12 PM
barrymacpuma
dose any one no if 1.8 cvh engines came with power steering.
I was hopen to keep my puma with power steering.
a was thinking about a dry rack with corsa colum but lots of work.
ANY IDEAS
Old 11-04-2012, 09:28 PM
barrymacpuma
just got thread xr2 on 40s. i should have got a frst instead of erst.
my block has hole for tdcp. i am going to try sores every thing to efi
my engine.
this is my first convertion jumped in head first...
is my mfi head useable.
Old 11-04-2012, 10:21 PM
Dan j
Van modder
Dan j's Avatar
Escort mk5/6 cvh 1.4 had pas maybe you could use it
I do have the bits in the shed
Old 11-04-2012, 10:25 PM
Pudnpepsi
Pudnpepsi's Avatar
Barry I have a efi head. And a pas setup for a cvh block.
Old 23-04-2012, 09:02 PM
barrymacpuma
alright. power steering parts for cvh engine..
pump and mounts.
do you no if that runs on the same belt as alternaror.
is it a dubble belted crankshaft pully i need..
cheers..
Got started on my wiren loom. striped everthing i didnt need off.
so i was left with 2 ecu.s and 2 relay.s and my sensor plugs.
It was lookin good so pluged it all in, got the booster pack on to it.
the fuel pump was on,
BUT NOT. sparkin
back to the manuals
I am lookin for any one that can help or provide a engine bay wiren loom.
or good electricians or rs machic in glasgow
04-01-2024 02:36 PM
Ben26
11-08-2015 04:19 PM
knight19770
04-08-2015 12:36 PM
Quick Reply: Ford CVH engine in Puma - Project
