what pinto camshaft is this? cam timing won't line up
Old 05-04-2012, 10:59 PM
Jumpinjacks
Jumpinjacks's Avatar
Default what pinto camshaft is this? cam timing won't line up
Hi all,
I have a 2 litre pinto engine from a Sierra in a Morris Oxford and I can't get my cam timing to line up with the mark on the cam pulley, it either goes one side of the dot or the other. I have inspected my camshaft and I can see the following marks in the end nearest the bulkhead
: GA Z9455
And the mark: GC 5 on the top. Is this a standard camshaft or different?
Any help will be much appreciated.
Thanks.
Old 06-04-2012, 09:58 AM
martysmartie
martysmartie's Avatar
Hi,
I have seen this done before, is it a Series VI Oxford? I guess you have the 5 speed box as well?
Sorry, can't help you with the camshaft question though.
Old 06-04-2012, 11:19 AM
Jumpinjacks
Yes it is, and yes I have a 5 speed type 9 box
Old 06-04-2012, 12:30 PM
worm
worm's Avatar
Smile
hi if its a ford cam it will have ford stamped inbetween the lobes towards the rear if i remember correctly
Old 06-04-2012, 01:54 PM
martysmartie
Dad has the same, bet it goes far better than the standard B series engine or at least it will do once you get it running.
Old 06-04-2012, 02:04 PM
DAN400
DAN400's Avatar
most of the race cams i ve worked with in stock cars through the years all had ford stamped on them,
most are standard ford cams reground
Old 07-04-2012, 09:33 PM
Jumpinjacks
This one only had the figures mentioned. I can't see the ford badge anywhere
big_Rad
15-09-2017 09:36 AM
martsmotor
Ford Focus Range
27-08-2015 08:08 PM
20
22-08-2015 03:23 PM
Bailes1992
16-08-2015 07:14 PM
wheelwizardrefurbs
06-08-2015 07:40 PM
Quick Reply: what pinto camshaft is this? cam timing won't line up
