numberplate light. MOT fail?
Old 18-03-2012, 11:26 PM
muffster
muffster's Avatar
Default numberplate light. MOT fail?
Is having a bulb out on a numberplate light an MOT fail?
It's on my 320D, it's got 2 lights and one has gone, the other one works.
It's not just a simple case of a new bulb, the holder is all corroded.
So is an MOT failure?
Cheers.
Old 18-03-2012, 11:35 PM
Oranoco
Oranoco's Avatar
To the best of my knowledge if it has 2 lamps both need to work for a pass
Old 19-03-2012, 01:01 AM
Chopshop85
Chopshop85's Avatar
I think its pretty much...If its there, its got to work from an MOT point of view.
Old 19-03-2012, 08:26 AM
RS2000CUSTOM
RS2000CUSTOM's Avatar
If you have 2 seperate number plate lamp assemblys each with 1 bulb per assembly and a bulb is not working in one of them then it is a fail
But (there are always buts in MOT) if you have one number plate lamp assembly (with no divider between internal reflector or the bulbs) with 2 x bulbs and one bulb is not working then it is a pass and advise
There is a new test criteria just been added that requires 50% of the light source to be working
This was mainly bought in to cover multi LED powered lamps but is relevant to bulbs as well
So if you have for example 6 leds in 1 single number plate assembly then 3 working LED's is a pass and advise
Hope this helps
Old 19-03-2012, 11:43 AM
stevieturbo
C**t
stevieturbo's Avatar
Certainly always been a fail here.
Old 19-03-2012, 07:22 PM
muffster
muffster's Avatar
Great, thanks for the heads up.
Ta.
Old 19-03-2012, 07:33 PM
stevieturbo
C**t
On some of the BM's, you may need to replace the entire plate surround as the terminals for the bulb corrode badly
Old 19-03-2012, 10:13 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
Hope this helps
Couldnt have put it better my self
Old 19-03-2012, 10:54 PM
RS2000CUSTOM
cheeRS Matt
I have just passed my Motorbike (class I & II) MOT tester course and no number plate lamp at all is OK - lol - Not even a testable item on Class I & II
Old 20-03-2012, 12:38 AM
cossiestu
cossiestu's Avatar
There's a thread on bimmerforums on how to chop out the corroded holder an rewire in a holder from e-bay. Cheaper than paying £160 odd for a new BMW lamp. If you can find one in a breakers, the early e46 ones are different....
Old 13-09-2017, 11:50 AM
JACK1109
JACK1109's Avatar
Default Number plate lights
Guys,
I removed one of the number plate lights and fitted a reverse camera in its place. Will this now fail MOT. The other light is still there and working though.
Old 13-09-2017, 11:59 AM
john_p_b
john_p_b's Avatar
Originally Posted by JACK1109
Guys,
yes.
get some adhesive led light strip and fit that to get through test.
Old 13-09-2017, 03:12 PM
stevieturbo
C**t
Obviously it's entirely down to the tester but there should be working number plate lights.
Old 13-09-2017, 03:20 PM
JACK1109
JACK1109's Avatar
Originally Posted by john_p_b
yes.
thank you. Might have to do that.
Old 13-09-2017, 03:22 PM
JACK1109
JACK1109's Avatar
hmm. Don't really want to take a chance. I got one light working so thought might get away with it. Will have to see if I can do what has been suggested before.
Old 13-09-2017, 03:57 PM
gingeRS
gingeRS's Avatar
i found a faulty one on my old E39 and had to rewire the whole tailgate to get it working again
Old 13-09-2017, 07:02 PM
Is this all the car failed on??
Lol. Its a 5 year old thread.
gcfcos
59
06-10-2015 05:04 PM
SMILER258
36
28-09-2015 09:04 AM
Quick Reply: numberplate light. MOT fail?
