Lambda Sensor sierra 2wd cosworth
Old 27-01-2012, 11:45 AM
revs1
revs1's Avatar
Default Lambda Sensor sierra 2wd cosworth
Ive just recently changed my intercooler to a rs500 one and replaced the radiator and fitted a new t34 turbo.
It used to run a 4x4 intercooler with a t34 turbo but have now got the bigger housing one
Ive been told I will have to get it re mapped and need to get a lambda sensor put in??
Any suggestions?
Forgot to say its had stage 3 and running dark greens
Old 27-01-2012, 12:06 PM
revs1
revs1's Avatar
<tftfitfotftf
Old 27-01-2012, 12:08 PM
revs1
revs1's Avatar
Old 27-01-2012, 12:12 PM
revs1
revs1's Avatar
Old 27-01-2012, 12:14 PM
revs1
revs1's Avatar
Ok so got carried away and ended up changing alternator water pump pullies .......
Old 27-01-2012, 12:16 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
why do you need to put a lambda senser in? whats it for an afr gauge?
Old 27-01-2012, 12:20 PM
revs1
revs1's Avatar
was told to put one in so they could re map it?
revs1
revs1's Avatar
revs1
revs1's Avatar
That what she used to look like!
Old 27-01-2012, 12:34 PM
ajamesc
ajamesc's Avatar
No idea then mate lol is it still on a 2wd ecu? unless they wont to check the afr from there or is it going on wasted spark? i have one in mine on the down pipe about 4 inches from the turbo but its there for my afr gauge when its mapped the workshop one is used that gos in the tail pipe!
Old 27-01-2012, 12:57 PM
revs1
revs1's Avatar
yep still on the 2wd ecu, L6 is meant to be much better....
Old 27-01-2012, 01:35 PM
Rab
Fucking superstar........
Rab's Avatar
I think the lamda sensor suggestion was for a MSD type closed loop conversion. This gives massively improved fuel economy and driveability off boost. You can re-map it without so it's not essential.
Old 27-01-2012, 02:36 PM
ajamesc
ajamesc's Avatar
if its not on wasted spark there is no reason at all to have a lambda senser mate id ask them what they need one for lol
Old 27-01-2012, 06:05 PM
martysmartie
martysmartie's Avatar
L6 is 2WD (Saph) L1 is 3DR, there is no benefit to be had from the L6.
If you want things like CL, WS, ALS, LC etc then you want a L8.
Alot of tuners do like to fit a lambda when live mapping on the road.
Wasted spark is avaliable on the whole family, so L1 and L6 as well.
Old 27-01-2012, 06:21 PM
saph cos rob
swindon rsoc
saph cos rob's Avatar
is there not? i know of a few people who ripped out the L1 and changed for the L6?
charliecosworth
19-08-2015 02:00 PM
cossie4x4
14-08-2015 06:29 PM
14-08-2015 11:21 AM
dal3door
13-08-2015 06:55 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: Lambda Sensor sierra 2wd cosworth
