This week I av been mostly!
Old 02-07-2011, 07:37 PM
tosh
tosh's Avatar
Default This week I av been mostly!
De-rusting parts with apple cider vinegar, all I can say is wow just leave them soaking for a couple of days and wire brushing couple of times and hay presto the rust has gone, but don't rinse them with water because you will get flash rust all I done was clean them with brake cleaner afterwards,
I just thought I would share it with you guy's
Old 02-07-2011, 07:41 PM
paul16v
Monte 087
paul16v's Avatar
It really does give good results dont it? ive currently got a load of bolts off mine soaking away
Old 02-07-2011, 08:18 PM
RichieST
RichieST's Avatar
I've done it before it works well, cheap vinegar works well too!
Old 02-07-2011, 08:40 PM
tosh
tosh's Avatar
I was told about it ages ago but thought nothing of it, you just need to be careful if soaking parts with polished surfaces like hub flanges etc as it will dull them and take the shine off the areas that aren't rusty but yes I couldn't believe the results you end up with it just dissolves the rust like magic with very little effort.
Were did you guy's get yours from I can only seem to find it in morrisons but it is 97p for a 500ml bottle?
Old 02-07-2011, 08:41 PM
RichieST
RichieST's Avatar
I just used the cheapest of cheap asda basics vinegar!
Old 02-07-2011, 08:44 PM
paul16v
Monte 087
paul16v's Avatar
Me too, tescos cheapest lol
Old 02-07-2011, 08:47 PM
tosh
tosh's Avatar
I was told apple cider vinegar works best for some reason I think it has a higher acidity % or something, was it malt vinegar you used or the white clear stuff
Old 02-07-2011, 08:53 PM
RichieST
RichieST's Avatar
The malt vinegar I used, although the clear stuff might work just as well!
Old 02-07-2011, 09:00 PM
tosh
tosh's Avatar
I will give it a try but I have still got 3 ltr's to use I think I went a bit ott on the amount I purchased.
I also had a look on you tube and you can use Molasses mixed with water what ever that is?
Brickhouse
14
03-10-2015 07:28 PM
Fiddy
21
29-09-2015 06:10 PM
rsguy
44
29-09-2015 03:29 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: This week I av been mostly!
