Oil return Line Fitting pg. 2
Old 11-06-2011, 06:38 PM
Canada1
Canada1's Avatar
Default Oil return Line Fitting pg. 2
Finally having some time to assemble the 1.9 cvh turbo engine destined for a fake
Escort RST.
1.9 block back from machine shop. 82.5mm bore (0.5mm oversize)
Custom CP forged pistons - 8.2:1 CR
Pistons and connecting rods assembled
Decided to keep the factory breather cover in place.
Found my Hazet piston ring compressor tool
After some trial fitting I had to chamfer the bottom of the cylinder bores for connecting rod clearance. It was a bit tight with only 0.020" clearance.
Engine clearances were fine:
Main Bearings: 0.0022"
Rod Bearings: 0.002"
Piston to Cylinder: 0.005"
Piston to Deck: 0.004"
Notice ft. lbs. torque required for correct rod bolt stretch of 0.0055" written on connecting rod beams.
Oil pump install next!
Old 11-06-2011, 08:30 PM
BRAM
BRAM's Avatar
Have been waiting for you to start a build thread!!!!
Keep up the good work mate
Old 11-06-2011, 10:05 PM
Nice fella.keep up the updates.
Old 12-06-2011, 09:32 AM
gus
gus's Avatar
good work so far
Old 12-06-2011, 09:37 AM
Ben26
Ben26's Avatar
nice mate , why the 1.9 ? are they more common over there ?
Old 12-06-2011, 01:53 PM
Maxwell
Irregular Poster
Maxwell's Avatar
I wondered why you hadnt done a build thread yet either!!
Pics of the car needed though
Old 12-06-2011, 04:18 PM
Canada1
Canada1's Avatar
The 1.6 cvh escort was around from 1981 to first half of 1985.
1985 and later had the 1.9 sized engine. The best one for a performance
build is the 1.9 HO engine. 108 and 110 hp versions.
The 1.9 is more common to find in the wreckers yards.
Old 13-06-2011, 09:12 PM
Marcyg
Marcyg's Avatar
I 'believe' the block is the same as the 1.8 cvh Sierra we get over here, but with a different crank etc
Old 14-06-2011, 04:10 PM
Canada1
Canada1's Avatar
Hello Marcyg,
The 1.8 cvh Sierra uses the same 88mm stroke crankshaft the 1.9 engine uses.
The north american 1.9 has an 82.0mm bore size. I believe the 1.8 Sierra has
the 80.0 mm bore size. I am not sure if the small bore Sierra block is taller than the regular 1.6 block.
The cranks are the same, and the blocks are different.
Old 14-06-2011, 04:48 PM
Maxwell
Irregular Poster
Maxwell's Avatar
Get pics up of the car pleeeeaaassseeee
Old 14-06-2011, 04:53 PM
studabear
studabear's Avatar
Looking good Perry, I like your posts on the cvh engines etc
(and as maxwell says lets see the car its going in)
Old 14-06-2011, 05:20 PM
Canada1
Canada1's Avatar
1986 escort inside view.
Outside view does not look like much yet - needs proper wheels and tires
Old 14-06-2011, 05:27 PM
Canada1
Canada1's Avatar
235 mm clutch for 1.9 cvh - Centerforce performance cluch for a 1990 3.0 liter Taurus SHO (Yamaha V6 220 HP engine)
A mixing and matching of flywheels (2.3 Turbo XR4Ti or 2.3T Thunderbird) bolts up to 1.9 cvh crankshaft - same OD as factory 1.9 flywheel, but allows for the 235mm clutch instead of the small 215mm clutch.
Old 15-06-2011, 09:18 AM
Kevin_Mc
Kevin_Mc's Avatar
get updating on oddkiddcreations as well mate, i've got some questions for you!
Old 15-06-2011, 05:50 PM
Canada1
Canada1's Avatar
What questions? Could aske me here?
Old 15-06-2011, 05:52 PM
Canada1
Canada1's Avatar
Getting closer!!
Old 16-06-2011, 02:19 AM
Maxwell
Irregular Poster
Maxwell's Avatar
Thats an odd looking sump!!
Old 17-06-2011, 08:04 PM
Canada1
Canada1's Avatar
Standard 1.9 tall block sump.
Another angle:
Old 20-06-2011, 12:01 PM
Kevin_Mc
Kevin_Mc's Avatar
sorry Perry, didn't see your reply until after youposted on OKC
Old 25-06-2011, 05:28 PM
Canada1
Canada1's Avatar
Test fitting turbo manifold and turbo.
Have a few small issues with the alternator bracket
I will think of something.
Old 25-06-2011, 06:11 PM
studabear
studabear's Avatar
whats the issues with the bracket perry?
Old 26-06-2011, 09:41 AM
Maxwell
Irregular Poster
Maxwell's Avatar
I was on ebay us yesterday and was flicking through american spec escorts! I noticed the door card in the pic you posted and noticed a 1982 escort exp had the exact same door card! Is that the model of escort your doing this conversion to?
Old 26-06-2011, 09:03 PM
Canada1
Canada1's Avatar
Hello Maxwell
I replaced the standard door panels with ones from a 1985 ( I think) Escort EXP.
I also took the seats from the Escort exp.
They look nicer than the standard Escort ones.
Old 26-06-2011, 09:17 PM
Maxwell
Irregular Poster
Maxwell's Avatar
Ahh ok mate!!
Have you any pics of your inlet? And of the throttle bodie position!!?
I was looking at how tall and also the shape of your rocker cover, and i was thinking of where you will have the charge pipe. I think you should be uber cool and get a proper rs turbo cover and charge pipe and inlet!! Would be a nice touch in your engine bay!
Old 11-07-2011, 02:05 PM
Canada1
Canada1's Avatar
Hello Max,
The inlet is a side trottle body.
I have upgraded the standard 50mm throttle body to a 56mm BBK version designed for a 3.8 V6 Mustang.
The factory inlet has been modified internally to balance flow and increase flow as much as possible.
Old 15-07-2011, 11:56 PM
Canada1
Canada1's Avatar
Default Degreeing Camshaft
Degreeing roller lifter camshaft:
I will start with maximum valve lift at 115 degrees BTDC.
Old 26-07-2011, 08:50 PM
Rob_DOHC
Rob_DOHC's Avatar
Just seen this Perry! Good work!!
Rob,
Old 27-07-2011, 03:17 PM
Canada1
Canada1's Avatar
Thank you Rob!!
Old 28-07-2011, 04:57 PM
Canada1
Canada1's Avatar
Default Cylinder Head Has Arrived!
Cylinder head has arrived!
Port cross sectional area was kept on the small side to promote high velocity.
We ended up at 330ft/sec at 6500 rpm.
The finished ports are very quiet on the flow bench, and show no turbulence
all the way up to 48" of water.
The exhaust port was kept small to keep up velocity for turbo use.
If money was no object the exhaust port floor would be welded up and raised.
The inlet port is tricky to increase airflow. The swirl type port requires someone
with experience to get them to flow without losing all the port velocity by grinding it
larger everywhere.
We did experiment on 2 cracked heads to see where material removal was beneficial,
or detrimental in some areas.
Just grinding the port bigger made little flow gain.
Old 04-08-2011, 10:53 PM
Canada1
Canada1's Avatar
Turbo fittings have arrived.
AN fittings for water and oil.
Old 10-08-2011, 09:15 PM
Canada1
Canada1's Avatar
Haltech installation begins.
Under center of dash plate.
Old 10-08-2011, 09:19 PM
Ginge
www.virtualseason.net
Ginge's Avatar
Looking good squire, so nice to see something different for a change... well different to me anyway!
Quick question, got a pic of your porker or even better a video, i need to hear those carbs
Ginge
Old 11-08-2011, 10:14 PM
Canada1
Canada1's Avatar
Default 3" Down pipe Install
Fitting new 3" V-Band down pipe with the ATP T3 5 bolt high flow V-band style internal wastegate.
I couldn't bring myself to use the restrictive factory down pipe. This should improve turbo spool up and reduce excessive back pressure.
Rule of thumb for turbo exhaust sizing is 1.5 X size of turbine exducer. 1.89" X 1.5 = 2.83" So 3" OD exhaust should be perfect.
Old 12-08-2011, 05:53 AM
Old 12-08-2011, 08:04 AM
Ben26
Ben26's Avatar
its lookin smart mate, the rocker cover seems very very different as well, what sort of power are u going for ? will u be using the seimens range of injectors ? this engine will be EFI yea ?
Old 12-08-2011, 10:12 AM
Rob_DOHC
Rob_DOHC's Avatar
I think theres a pic of his ecu above mate, so im assuming efi yes
Perry, awesome work, I think you have a little more room than us in the bay?
Liking the down pipe, very big flex joint though? And i take it the two bungs are for EGT and Lambda?
Im very tempted to have an EGT sensor in each manifold runner when i go fully sequential so i can match the fueling on each pot.
Best of luck and keep the pics coming!
Rob,
Old 13-08-2011, 04:45 PM
Canada1
Canada1's Avatar
I am using RC fuel injectors - 550 cc/min (52 lbs/hr)
These injectors should be fine up to about 250 hp @ 80% duty cycle.
I will only be using one exhaust bung for the wideband O2 sensor.
Old 17-08-2011, 01:06 PM
Rob_DOHC
Rob_DOHC's Avatar
Come on Perry, it must be update time by now?
Rob,
Old 08-09-2011, 01:09 AM
Canada1
Canada1's Avatar
Hello Rob, update just for you
Escort RST head gasket - very high quality thick steel core.
Gasket bore size just slightly larger than 82.5mm
I put the new cylinder head on - torqued in 3 steps 20, 40 and 60 ft. Lbs.
I will re torque after a 24 hour period, and once again after engine is run in.
A pain in the ass I guess, but required with head studs.
Crower dual valve springs, valve retainers, and valve spring seats (To hold spring steady at bottom)
Old 27-09-2011, 02:25 PM
Canada1
Canada1's Avatar
Engine ready for flywheel and clutch.
Added 36-1 crankshaft sensor to front pulley. Made a new pointer for TDC.
0, 10, 20 and 30 degree markings on pulley to verify engine management timing
mapping.
Quick Reply: Oil return Line Fitting pg. 2
