Sponsored by:
Sponsored by:
Neat positive side battery terminal connections
Old 05-05-2011, 02:20 PM
Smit
The 60ft Launch King
Smit's Avatar
Default Neat positive side battery terminal connections
I must have 10 wires on my positive side of my battery it looks a total fookin mess!
First off has anyone done a neat custom bracket or connector?
Piccys if anyone has please.
As i want to sort mine once and for all.
Thank you please
Smit
Old 05-05-2011, 02:23 PM
R5FORD
R5FORD's Avatar
me too.
Old 05-05-2011, 02:24 PM
avinit1rs
AV IT!!!
avinit1rs's Avatar
I have been looking for some thing also as i have a few fuses and cables everywhere, was going to try and hide it behind the battery. Still undecided - have a look on here it might give you some ideas.
https://www.electricalcarservices.co...25b-p-378.html
Old 05-05-2011, 02:25 PM
dojj
Resident Wrestling Legend
dojj's Avatar
remove all the wires from the terminal
relocate them inside a big plastic box
connect big fat lead to the terminal
terminate lead at the other hidden side inside the box
job jobbed
Old 05-05-2011, 02:34 PM
Smit
Smit's Avatar
I quite like the look of something on there....
You could just mount it somewhere and looks a lot tidier than what i've got at the minute!
£28.99 though, not cheap!
Old 05-05-2011, 02:55 PM
KSA-Cossie
KSA-Cossie's Avatar
Looki ng for something like that myself Mark.
Old 05-05-2011, 05:32 PM
Smit
Smit's Avatar
Looks alright doesn't it Kev... Going to have a good look around now i've finished tea.
Will post up if i see anything suitable at a decent price
Old 05-05-2011, 05:50 PM
LukeDaisley
LukeDaisley's Avatar
http://cgi.ebay.co.uk/6-WAY-STANDARD...ht_1219wt_1139
Old 05-05-2011, 05:57 PM
Smit
Smit's Avatar
That's not what i'm after...
Really want a 1 into 6/8 distribution box not 6/8 into 6/8 with fuses in the middle.
If you see what i mean............
Old 05-05-2011, 06:22 PM
James
James's Avatar
what i did with mine was the mk5 escorts had a little fusebox that bolts to the positive terminal of the battery then all the wires bolt up inside this with the big fuses inside.
looked factory aswell!
Old 05-05-2011, 06:28 PM
Smit
Smit's Avatar
Well after shopping about there generally was a whole load of junk advertised! Some of the boxes looked fookin shonky and still wanted top money Fuck that.......
Ended ordering the item above.. The 6 Pole fuse box
It was £26.95 delivered, will do a thread when i've got an afternoon free to install it
Old 05-05-2011, 06:33 PM
focusv8
focusv8's Avatar
All you needed was one of these as dojj suggested £7 or £8;
http://www.vehicle-wiring-products.e.../photo/pj1.jpg
or;
http://www.vehicle-wiring-products.e.../photo/pj2.jpg
Old 05-05-2011, 06:34 PM
whizzisat114
whizzisat114's Avatar
Im sure there 's something like this in the demon tweeks catalouge page 111 top right or
if you wanna look on tinternet look up battery distibution board www.demontweeks.co.uk
And your welcome
Old 05-05-2011, 06:41 PM
Smit
Smit's Avatar
I did see them but they were £14.50 delivered, which seemed a bit pricey for a bit of plastic with a connector in.......
Agreed the would do the job, anyone after a cheap alternative look no further
Old 05-05-2011, 06:44 PM
Mark V8
Mark V8's Avatar
Neat but pricey
http://www.demon-tweeks.co.uk/Perfor...rd/646/0/14805
Old 05-05-2011, 07:19 PM
I use a Marine pole socket for my live wires, too many for battery, it's a post that secures to a flat panel, then has a 6mm stud that you bolt all the terms onto, comes with neat cover and is waterproof as marine, cost was around £6.
For the negative side I used a positive side battery multi connector bit , bent the retaing bracket from sticking up to down now flipped over and it fits on the negative side perfectly, and of course being a mirror image of the positive side one it is factory looking, and free from most scrappies!!
vaughant
vaughant's Avatar
Would have been my suggestion,in fact any escort up to 1995/6 when they changed over to round types.
Old 05-05-2011, 08:14 PM
KSA-Cossie
KSA-Cossie's Avatar
Nice one Mark,mind the pics.
Old 06-05-2011, 11:59 AM
bunnymofo
bunnymofo's Avatar
yes i defo kneed something like this. just too many wires for the battery : ( will have a dig, see if i can find anything else
Old 06-05-2011, 12:04 PM
funkybrian
funkybrian's Avatar
http://www.furneauxriddall.com/acata..._Fuse_Box.html
This looks tidy enough
Old 06-05-2011, 12:05 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
as previously suggested get one off a later ford we use the escort cosworth power distribution battery fuse pack on the 3 doors and sapphs
Old 14-09-2012, 05:16 PM
adam151082
adam151082's Avatar
Did anyone get somthing sorted with this cos i need somthing doing
Old 14-09-2012, 06:01 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Mine has one wire going to the battery all the others go into a junction box
Old 14-09-2012, 07:47 PM
stevieturbo
C**t
stevieturbo's Avatar
Take a look at the VAG stuff. They run a small fuse box off the battery, with high amp fusible links inside and terminals.
search egay for VW Battery fuse box etc. There are various designs. TPS will sell them at reasonable prices. Some of the egay prices are actually high.
http://www.ebay.co.uk/itm/VW-MK4-Gol...f#ht_779wt_961
Old 14-09-2012, 07:53 PM
ajamesc
ajamesc's Avatar
this is how i did mine
Old 14-09-2012, 07:56 PM
adam151082
adam151082's Avatar
What junction box is that m8? You got a ebay link?
Old 14-09-2012, 08:01 PM
ajamesc
ajamesc's Avatar
I got it from demon tweaks
Old 15-09-2012, 01:35 AM
Smit
Smit's Avatar
I'll put a picture of mine up on sun when I'm home
Old 15-09-2012, 07:02 AM
GARETH T
GARETH T's Avatar
http://cosworth.com/products/motorsp...-units/hyllus/
This is the neatest solution
Old 15-09-2012, 07:56 AM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Neatest solution is to put the battery in the boot.
Old 15-09-2012, 08:05 AM
cossiestu
cossiestu's Avatar
Been wanting to do that for ages, but unsure of what gauge cable to use etc...
Old 15-09-2012, 08:10 AM
stevieturbo
C**t
Neatest solution is a wireless bluetooth fuse box.....
Old 15-09-2012, 08:14 AM
stevieturbo
C**t
35mm^2 welding cable is more than adequate and ideal.
Old 18-09-2012, 06:17 PM
adam151082
adam151082's Avatar
Ok, what kind of cable will i need to run from the junction box to the battery, i want one cable so i guess its going to be pretty thick.
A ebay link would be nice as thats where im going to buy it
Old 18-09-2012, 07:27 PM
stevieturbo
C**t
The VW fuse boxes come with cable already fitted.
Size of cable will depend on the load you want it to carry though. 16mm^2 welding cable would be more than adequate.
Old 18-09-2012, 07:34 PM
mannion
mannion's Avatar
First thing i'd do is work out why there are 10 wires on the battery, surely some of those are going to be unnecessary and can be removed altogether.
For the wires you do need what's wrong with keeping it simple with this for £3
https://www.electricalcarservices.co...no2-p-173.html
Old 18-09-2012, 08:15 PM
ajamesc
ajamesc's Avatar
i went to an electrical factors we use at work who sells auto stuff as well with the wire from the starter to the battery and said i wont a length of this and as they only sell it in 1 meter lengths and i only needed half a meter he gave it to me lol but im not to sore what amp lead it is as it was a while ago now
Old 18-09-2012, 08:19 PM
ajamesc
ajamesc's Avatar
i thought this lol but when you get down to it they are all power feeds to various componants! it seems cossies do have a fair few wires to the plus side of the battery
Old 19-09-2012, 10:23 AM
cossiestu
cossiestu's Avatar
Not to mention a suitable size main fuse at the battery too, I should imagine!!?
Old 19-09-2012, 10:51 AM
ajamesc
ajamesc's Avatar
Theres no main fuse in it as it is standard! All the juction box is doing is moving the wires from one point to another. Plus all the componants that wire to the plus side no doubt have there own fuses anyway
Quick Reply: Neat positive side battery terminal connections
