FAO Stu re plugs for eec4 escos with chip
Old 25-01-2005, 11:19 PM
SteveW
SteveW's Avatar
Default FAO Stu re plugs for eec4 escos with chip
Hi Stu, could you please give me some advise, i took the plugs out of the cossie to check what one's are fitted. they are motorcraft agpr12pp8 then i rang my local ford dealer and the said listed on their system my car uses agpr12pp. Which should i be using and do you stock them?
Steve
Old 26-01-2005, 09:00 AM
Damo V
Damo V's Avatar
Hi steve if you post in the tech section, Stu lways in there mate
Old 26-01-2005, 12:21 PM
Dave Henshall
Dave Henshall's Avatar
the only difference IIRC betwwen the AGPR12PP and AGPR12PP8, is the the latter is pregappd to 0.8 mm.
i think the general consensusis nowerdyas though that they should all use the motorcraft AGP071
Old 26-01-2005, 08:04 PM
Speedy G.
Speedy G.'s Avatar
Dave,
NOT in the small turbo Esc Cos m8 !!!
Old 26-01-2005, 11:09 PM
Skiman
Skiman's Avatar
Small Turbo escort cosworth, the only plugs you can use are the standard ones, as far as im aware anyway.
tankybaby66
06-02-2016 02:24 PM
gcfcos
59
06-10-2015 05:04 PM
Brickhouse
14
03-10-2015 07:28 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: FAO Stu re plugs for eec4 escos with chip
