Lambda and O2 Sensor Question!
Old 07-10-2010, 01:13 PM
Kayble
Kayble's Avatar
Default Lambda and O2 Sensor Question!
Hey, it was my understanding that they are the same thing, but when looking for a decat manifold i came across one that said it had 2 holes cut for the Lambda and O2 sensors.
Its a Mk1 focus, so is there more than one, and where are they located, or is there just one, and where is it?
Old 07-10-2010, 01:21 PM
chaffe
Turbocharging Technician
chaffe's Avatar
some systems use two sensors to measure the cat efficeintcy, not sure if your car has this system. but lambda and o2 sensors are the same thing mate
Old 07-10-2010, 01:22 PM
Kayble
Kayble's Avatar
k thanks, i thought that, just wanted to check, i take it if mine only uses one then i can just block off the extra hole on the manifold?
Old 07-10-2010, 01:24 PM
chaffe
chaffe's Avatar
Yeah mate, or use it for a wideband gauge for tuning
Old 07-10-2010, 01:57 PM
martysmartie
martysmartie's Avatar
As said some have two they are usually referred to as pre and post cat, and I seem to remember the Focus does have two.
Old 07-10-2010, 04:10 PM
A 02 sensor is just that it measures 02, or rather oxygen content in the exhaust gasses, this sensor is usually termed lambda sensor by most but 02 sensor is more correct.
Lambda is signal(voltage) that it generates, a certain voltage is a certain lambda value, lambda 1 is the chemically correct ratio, called stoichiometric roughly 14.7:1, 14.7 parts of air to 1 part fuel, the ratio is actually a tad under but 14.7:1 good enough, 0.8 0.9 etc are comparisons to the chemically correct ratio.
Old 07-10-2010, 06:11 PM
chaffe
chaffe's Avatar
as i said they are the same thing
Old 07-10-2010, 06:58 PM
boyblew
boyblew's Avatar
hi do eany one have the p0172 on a st170
chowfornow
14
05-01-2019 09:01 PM
tankybaby66
06-02-2016 02:24 PM
Neil Clark
21
01-10-2015 07:02 PM
Si B
12-09-2015 06:49 AM
Quick Reply: Lambda and O2 Sensor Question!
