focus knocking
burning oil
focus knocking
I got my 2004 focus tdci sport lowered last night but now have a terrible knocking coming from the front which sounds mainly the passenger side.
The springs i used were spax 35mm although i dont no the exact model of focus they are for.
The back is sitting what i would say 35mm however the front is sitting slightly lower maybe 45-50mm which i would say is due to the extra weight of the diesel lump.
There is no play anywhere and everything is nice and tight
The knocking only occurs when going over bumps. Has anybody else experienced the same when lowering there foci
No prob, i had the same problem after lowering. I heard the knock when going over bumps, thought maybe shocks where shot, so got new ones, but still same knock. My links kept breaking their ball joints. That's when i noticed little dents in the chassis exactly in the line of travel of the Roll bar and links
burning oil
Thanks for the advice I'm going to have a closer look tonight. Where abouts did you buy your longer drop links from. Is it something I can get from my local motor factors
I know the guy in my local garage, so i just took my links off, and took one down, and just visually compared them to a bunch of links that were lying around. Then bought the pair off him which looked about 40mil longer. So not sure which make and model sorry
burning oil
After a bit of searching it seems that astra g drop links are longer. The vaux boys use focus mk1 drop links when going low on coilovers apparently because they need shorter drop links on the astra
