Immobiliser key recoding
Old 20-09-2010, 11:52 AM
kenny ken
kenny ken's Avatar
Default Immobiliser key recoding
Hi Guys
The unlock button on my key fob broke, can still lock and start the car though. Got another keyfob from fleabay and done the first part the coding to lock and unlock the doors but cannot get it coded for the immobiliser.
Procedure I've followed to code the immobiliser is:
Put the 1st key in, turned to position 2, removed key. Insert the 2nd key, turn to position 2 and remove. Then insert the new key and this should code it to the ignition.
Has anyone had any luck with coding keys to the immobiliser or is this a dealer job??
Thanks in advance
Old 20-09-2010, 12:56 PM
danme1987
danme1987's Avatar
you need two coded keys already to code others. its a dealer job if you only have the one key coded. sound like a dealer job or locksmith if you can find one that does cars
Old 21-09-2010, 07:34 AM
kenny ken
kenny ken's Avatar
Yeah I have 2 coded keys already. I'll take it to a dealer to see how much they'll sting me for
Old 21-09-2010, 08:02 AM
taz1787
Escort Cabriolet Owner
taz1787's Avatar
ok get both coded keys ( a and b )
insert key A to pos 2 wait 1 sec remove
insert key B (within 5 secs) to pos 2 wait 1 sec remove
wait 10 secs
insert new key to pos 2 wait 4 secs
switch off ( do not remove) wait 5 secs
start engine
if engine does not start and clock led flashes
switch ign on wait at least 20 secs
switch off repeat programming procedure
hope this helps
Old 21-09-2010, 08:08 AM
rubinsbin
rubinsbin's Avatar
Sound ok that-------------what car??
Old 22-09-2010, 03:00 PM
kenny ken
kenny ken's Avatar
wait 10 secs
start engine
hope this helps
Thanks for that Taz, tried that but still failed. I think the key may be faulty
Old 04-10-2010, 03:11 PM
Archibald
Archibald's Avatar
You can always take paired transponder from you old key fob and put it the one from e-bay. Just pull it gently from the rubber sleeve inside the fob.
Old 19-02-2013, 02:44 PM
steffs234
steffs234's Avatar
Hi i have a 2002 focus 1.8 16v and my button key fob buttons are broke could i change ignition barrel and locks and remote control box i have taken out of another car that has both keys one with the fob the other with chip or do i still need this programed into the ecu.... many thanks
tankybaby66
06-02-2016 02:24 PM
A.t.p
23-10-2015 07:54 PM
Daniel Howard
17
26-09-2015 12:39 AM
Flatlinedan
18-09-2015 12:41 PM
NC53
13-09-2015 03:05 PM
Quick Reply: Immobiliser key recoding
