Lumenition Air fuel ratio meter
Old 04-02-2010, 10:29 PM
cosy trav
cosy trav's Avatar
Default Lumenition Air fuel ratio meter
Ive just bought a Lumenition Air fuel ratio meter and wondered if you can use these meters to set up the base mixture ? Its the 19 LED version .
Old 05-02-2010, 06:30 AM
oldford
oldford's Avatar
I doubt it. These use usually narrow-band oxygen sensors.
I use a wideband unit, something like this: http://www.plxdevices.com/wideband.html
Old 05-02-2010, 10:09 PM
cosy trav
cosy trav's Avatar
The reason im asking is that when its idling its 2 yellow leds above Lambda 1 setting and goes to the 1st green light when boosting which means it running rich but not getting to the max power mark at 3 green leds so was going to turn the co screw clockwise a bit to richen it up a bit but didnt want to upset the idle co setting . Im new to all this tuning malarkey LOL .
Old 05-02-2010, 11:12 PM
bad boy rs
bad boy rs's Avatar
i wouldnt adjust anything using a narrow band mate
Old 06-02-2010, 01:42 PM
The overall fuel graph is fixed by the chip so affecting one end of the scale will affect the other.
So long as it's a decent chip and set to the CO advised by the maker/supplier I wouldn't take any notice of what the gauge says, narrow band are very accurate but only over a very short range.
DixieTheKid
11
06-06-2020 11:20 AM
27-10-2015 04:55 AM
07-10-2015 03:43 PM
kevin36
09-09-2015 11:12 AM
kevin36
08-09-2015 12:23 PM
Quick Reply: Lumenition Air fuel ratio meter
