sierra trackday top mounts
Old 12-01-2010, 11:25 PM
ital_cossie
ital_cossie's Avatar
Default sierra trackday top mounts
hello,
i would like your opinion which top mounts are a good option for a trackday caged sierra 3 door. I found the following in some photos but i don't know who makes them....
if you know something else which you have tested let me know...
the setup of the car will be bilstein coilovers with compression struts and adjustable tcas.
Old 13-01-2010, 10:59 AM
LHD220Turbo
LHD220Turbo's Avatar
not sure to be honest, but i hope someone on here can advise which is best
Old 13-01-2010, 11:15 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
any that locate UNDER the strut top of the shell like that should be fine.
be wary of any that mount on top of it though.
Old 13-01-2010, 04:29 PM
Char1ie
Char1ie's Avatar
Top one is an eccentric top mount. I think I paid about £60 for a pair. Comp Brake I think sells them. They allow you to introduce a small amount of camber and caster adjustment and they don't add much to the handling. Mine are in and back a little bit and running standard ride height.
Bottom one replaces the rubber mount with a nice spherical bearing. More expensive I thnk at £140ish and a very nice set up as it gets rid of the rubber mount and unsophisticated top mount and allows better movement if you adjusting the bottom of the suspension for camber, caster or track.
Neither one will add much to your handling as they really suit adjustable suspension set-ups and complement geometry changes at the bottom. Either is a good choice if you are making changes elsewhere.
Charlie
Old 13-01-2010, 07:13 PM
Paul_RS
Paul_RS's Avatar
Spied these on ebay - http://cgi.ebay.co.uk/Sierra-Escort-...item2ea8009ce1
No idea if they'd be good or not?
Old 14-01-2010, 08:46 AM
Touring Car Spares
Touring Car Spares's Avatar
Yes, theyre actually a bit better than the eccentric ones and loads cheaper .
charlie is partially right , they can be used set camber but have no bearing on the Castor ,they only lean the strut back as the fulcrum is still retained at the bottom knuckle , i personally dont really like the Eccentric versions as theyre the wrong size for the turret tower and unless your lucky theyre never fitted identically both sides .They also reduce the compression of the damper by over an inch due to the location of the bearing ,which is lower in the strut than the std kit ,if you want to go much lower you will run out of travel !
Fords later GpA & WRC cars all had Top mounts mounted ABOVE the turret as well as below ,albeit on a strengthened tower ,this was also raised by several inches to allow the car lower in Tarmac form and to allow greater suspension travel for Gravel .
Old 15-01-2010, 04:04 PM
ital_cossie
thank you all for your answers.
i have found also this type of rose jointed top mounts from rapid ford and i would like to know your opinion as they fit also with the std rubber (or powerflex)
the right 909 top mounts for 3 door cosworth are these ones?
Old 16-01-2010, 02:59 PM
Touring Car Spares
The bottom ones are for wide track only ,they only fit inside widened turrets . I wouldn't want any rubber at all in a vital suspension component so you have only really the Compbrake types on a budget.
jessie_rs
11
03-06-2019 04:57 PM
James Porter
28-10-2015 12:17 PM
FlashRS
13
31-08-2015 06:02 PM
Anutternutter
21-08-2015 06:07 PM
dal3door
13-08-2015 06:55 AM
Quick Reply: sierra trackday top mounts
