help needed on building my s2 rs turbo into a zetec turbo
Old 15-12-2009, 04:39 PM
dean richardson
dean richardson's Avatar
Default help needed on building my s2 rs turbo into a zetec turbo
hi all am looking for pictures and advice on how to do a zetec turbo . i currently have a s2 rs turbo thats been converted to an 1800 zvh . but i want to make it into a 2.1 zetec turbo (blacktop) . what i need to no is can i run on standard water and oil pump and were abouts do i put oil returns from the turbo is it best to put them into the sump or block . and what pistons and rods do i use . only wanting around 300bhp dont want to go to big . thanks
Old 15-12-2009, 06:00 PM
danny_boy699
chatter 4 life
danny_boy699's Avatar
run standed oil and water pump, oil returns i have put mine in the block, u can use c20let calibra turbo pistons
Old 15-12-2009, 06:03 PM
dean richardson
thanks mate i was told about calibra turbo pistons but didnt no if they would work . and does it matter if i was to put the oil returns into the sump . cheers
Old 15-12-2009, 06:10 PM
tommytxr
why o why do i do it!!!!!
tommytxr's Avatar
you can put the oil return in the sump just make sure its as high as you can get it ok
Old 15-12-2009, 06:15 PM
danny_boy699
chatter 4 life
the block needs reboreing for them and rods need modfielding, (sorry for crap spelling) i would put them in the block my self then they are high a nuff and not under oil, all if see jacko on here, he sells them then all u need is a 18mm drill bit
Old 15-12-2009, 07:24 PM
dean richardson
i already have it mate in my engine now as my bottom end is zetec . but i was told to put it in the sump . but just found out that you put them in tthe sump if its a dry sump or summat . so think i will jut put it strait in the block again .
Old 15-12-2009, 07:25 PM
dean richardson
another thing every body is using rover inlets . will i be ok to use mine its off a fiesta turbo
Old 15-12-2009, 07:56 PM
danny_boy699
chatter 4 life
fiesta 1 is fine, i only used rover as i have 2, or u can use a plastic 1 like a focus rs.
use what u can mate, whats up with your old 1.8 zvh mate
Old 15-12-2009, 08:29 PM
dean richardson
it keeps shitting the bottom end mate . so it needs a crank regrind and the lot now and set of shells but other then that its a mint car with a tidy shell its had a fair bit of money spent on it i just want it a bit more reliable so opted for a full zetec turbo . just seen your project and ust want to no have you got yours up and running yet looking a good thing mate
Old 15-12-2009, 10:56 PM
rst in breaking
rst in breaking's Avatar
i believe calibra pistons are only suitable for silvertops to get the right c/r
Old 15-12-2009, 11:00 PM
dean richardson
thanks mate have you any idea on what pistons and rods i should use . any help would be great cos i dont want to start ripping it to bits till i have all the parts cheers
Old 16-12-2009, 10:52 AM
danny_boy699
chatter 4 life
not yet mate got no spark
Old 17-12-2009, 08:22 PM
tezmanian devil
tezmanian devil's Avatar
your best off using a silver top zetec engine mate, with the black top you'l need to mod the mount, get a front mount alternator kit, mod the sump(as it get's in the way of fitting the starter motor, and fitting the o/s driveshaft.
alot easier using a silvertop
Old 18-12-2009, 09:04 AM
dean richardson
thanks mate . have you done the conversion as i have most of the things like a 1.8 sump and pick up pipe and i already have the brackets for the front mount alternator engine mount has been done and the cover for the hole in the block . and the car has been altered to efi for the fiesta turbo inlet manifold . and its got a big front mounted intercooler . its running on biege injectors and its got a motosports developments chip or some thing in the ecu which is ofab . is there out else that is needed apart from the pistons and con rods cheers dean
Billy_RS
05-09-2015 12:04 PM
Churtz
13-08-2015 06:40 PM
turbobill
09-08-2015 05:21 PM
Cameron
14
09-08-2015 06:28 AM
turbobill
01-08-2015 08:55 PM
Quick Reply: help needed on building my s2 rs turbo into a zetec turbo
