Focus rear light cluster removal
Old 22-11-2009, 01:07 PM
Farmer Giles
Farmer Giles's Avatar
Default Focus rear light cluster removal
Hi,
I need to replace the stop/tail bulb in my 2004 focus hatchback but I can't get the light cluster off.
I've removed the obvious torx screw but the cluster is still firmly clipped in and I don't know which way to move it to unclip it and I don't want to break it forcing it the wrong way.
If anyone can post a picture of one removed or just write a couple of sentences explaining how it's done I'd appreciate it.
Martyn
Old 22-11-2009, 01:08 PM
studabear
studabear's Avatar
theres a fastener on the inside
Old 22-11-2009, 02:28 PM
Farmer Giles
what, hidden behind the panels inside ?
I did look at those but thought there be a little flap to open or something if there was anything inside... guess that would be too easy...
Old 22-11-2009, 02:45 PM
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
focus' are easy, 2 torx crews and a wingnut in the boot. it's easy to get to.
Old 22-11-2009, 02:48 PM
studabear
studabear's Avatar
yeah, the wing nuts quite high up through a hole
Old 22-11-2009, 03:01 PM
Farmer Giles
Yep, easy once you know how.
All done, thanks for your help..
Old 22-11-2009, 03:02 PM
cjwood555
cjwood555's Avatar
Hole is underneath the parcel-shelf-side-support things. Bright yellow handle on it if 01> !!!!
Chris
Old 20-08-2012, 08:04 AM
Danny Midgley
Danny Midgley's Avatar
My brake light as gone too. The yellow handle thing, I undid that, what do I do next ?(complete novice!)
Old 20-08-2012, 08:06 AM
RichieST
RichieST's Avatar
Undo the two screws that you can see, the light cluster then pulls off. Untwist the bulb holder, old bulb out, new bulb in. Or if you really don't have a clue take it to halfords and they'll do it for you for a couple of quid.
Old 20-08-2012, 10:01 AM
Moderator
STeve's Avatar
headlamp bulbs are another story though
Old 20-08-2012, 12:18 PM
martysmartie
martysmartie's Avatar
I always found them fairly easy, although the passenger side is slightly more awkward to remove the cover, as the battery is in the way.
Old 21-08-2012, 03:13 PM
Danny Midgley
Thanks - easy when you know how
Regards
Danny
Old 02-12-2012, 04:25 PM
STAFFY OWNER
STAFFY OWNER's Avatar
On the rear light cluster of a 03 Focus hatch can someone just confirm whether there are 2 torx screws or just one. I've got to change a rear light bulb on mine and from what i recall on my other halfs Focus i could only see one torx screw when you lift the tailgate up and then there's a large plastic wing nut on the inside. Can anyone tell me where the second torx screw is?
Old 02-12-2012, 04:43 PM
martysmartie
I think it's one, but you would easily be able to see if there is another, plus the said nut underneath.
Old 02-12-2012, 04:55 PM
STAFFY OWNER
^^^^Cheers Martin. I looked at a couple of YouTube videos and they only showed 1 torx screw but that was on an American Focus so i wasn't sure if there were different variations.
Old 02-12-2012, 05:05 PM
Moderator
STeve's Avatar
defo one torx and one twist plastic wingnut inside boot 2 mins a side = simples
salsheikh
Ford Focus ST Parts for Sale
06-10-2019 07:56 PM
salsheikh
20-08-2015 12:22 PM
RsS2daz
14-08-2015 05:26 AM
sridgett
03-08-2015 07:26 PM
Quick Reply: Focus rear light cluster removal
