Help! Rev counter not working and battery light!
Old 03-11-2009, 10:15 AM
Shep_Cobain
Shep_Cobain's Avatar
Default Help! Rev counter not working and battery light!
Hi guys,
Took my fiesta RS Turbo out last night after a week of it sitting and the rev counter isnt working, however the speedo is working flawlessly. Now then, the battery light is on constantly but is very dim. Whenever i brake it goes bright. If i brake my front heated windscreen button light goes out, if i let go it comes back on....
None of the other dash lights work but the actually lights and brakes work fine.
Any ideas???
Old 03-11-2009, 10:25 AM
carlo
carlo's Avatar
Speedo works by cable so that wont have anything to do with a battery prob. Is all the earth's right on the engine?
Old 03-11-2009, 12:21 PM
RSTurboSI
RSTurboSI's Avatar
check the conection from your alternator to the battery, see what condition thats in, my rs did that and was fine after i sorted it.
rev counter could be something fuse or wirning related, or could be the dash wirning.
Old 03-11-2009, 02:03 PM
Rax
Rax's Avatar
This is exactly the same thing that happened on my mates lads xr2i,battery light on no rev counter and no front fogs.The plug had worked loose on the back of the clocks.2 minute job everything fixed
Old 04-11-2009, 05:55 AM
Shep_Cobain
right,
quick update, when i start the car in the morning or after about 10mins of it being off the battery light is no longer on. However, if i put my foot down hard the battery light then comes on and stays on.
Old 04-11-2009, 09:05 AM
Rax
Rax's Avatar
Have you checked what the alternator is doing ? Is the battery doing flat ?,and really I would check the plug on the back of the clocks.The car I mentioned previously was up for sale when this happened and a guy came to look at it and said the alternator was goosed and so were some of the electrics.The rev counter only worked if revved really hard,the fuel gauge worked intermittently,the battery light didn't work until you revved it and then it stayed on the front fogs didnt work and the tick over was all over the place,Its worth checking the plug imo and its free It took me 5mins to fix.
18-08-2015 05:56 PM
ekjim
17-08-2015 08:57 PM
cozzy jeff
14-08-2015 05:46 PM
stevierob
11-08-2015 09:08 PM
xr_craig
07-08-2015 06:00 PM
Quick Reply: Help! Rev counter not working and battery light!
