Focus towbar wiring ????????
Old 21-10-2009, 04:02 PM
gramsey
gramsey's Avatar
Default Focus towbar wiring ????????
Hi all. Im having some trouble wiring up the electrics on my girlfriends towbar to an mk2 focus. has anyone on here done it before?? maybe got some type of wiring diagram. the instructions i got of witter i cant make head or tail of. Do i need the 7 way by pass relay and the buzzer??
Any help/drawings/instructions guys would be great.. i need to get it done for tomorrow as shes takin the horses out to a show in the mornin
Old 21-10-2009, 04:13 PM
gramsey
gramsey's Avatar
bump
Old 21-10-2009, 04:51 PM
dojj
Resident Wrestling Legend
dojj's Avatar
if it's a plug and play system then it's easy
undo some of the trim in the back, find the loom conections, plug it in, put it back together again
you will need to power the relay for the indicators from another source that is live when the ignition is on or they will flash too fast/too slow and the tow ball wiring is easy as it's 7 wires all very clearly marked out
if you have problems just take a pic of what you are trying to do or post up the link to the witter bar you've got
Old 21-10-2009, 05:01 PM
gramsey
gramsey's Avatar
its not plug and play unfortunatly. Ill get some pics up now!
Old 21-10-2009, 05:05 PM
gramsey
gramsey's Avatar
Are these the loom connectors your talking about?
Old 21-10-2009, 05:11 PM
dojj
dojj's Avatar
yes mate
the witter stuff just plugs into them inline with the wires going to the tow bar wiring as well
you have to plug in both sides and it gives you all you need to do
Old 21-10-2009, 05:15 PM
dojj
dojj's Avatar
i'd take mine apart to show you what i mean, but it's fairly well screwed together
one bit of advice though, where ever you take the power for the indicators, make sure you can reach the fuse fairly easily, mine dangles in the rear just under the parcel shelf as i've taken it from the rear power outlet
Old 21-10-2009, 05:59 PM
gramsey
gramsey's Avatar
relay bypass
buzzer
Cables from 7pin socket
Old 21-10-2009, 06:01 PM
gramsey
gramsey's Avatar
cheers for the help dojj, still aint got a clue
Old 21-10-2009, 07:21 PM
dojj
dojj's Avatar
aha, you've got a power point going on thre as well, which complicates mattes a tad
i think you may have ot post up the twitter instructions and then load sof us can see what they are confusing you about
Old 21-10-2009, 09:46 PM
The buzzer is a legal requirement, I think the thing that may be confusing you, is the lack of mention on some witter instructions of the need to cut the original feed wires to the indicators, the buzzer is then inserted in between the original feed and the indicator lamp/s, 1 of the other wires on the buzzer goes to earth, the remaining 2 go to the trailer socket.
Look on www.towingandtrailers.co.uk on here is a excellent, CLEAR diagram under 12N electrics.
The normal towing plug on cars is called 12N(for Normal), and is coloured black, there is an extra socket some have/may need that powers such things as caravan battery charging, fridge etc, called 12S(for supplementary), not needed though unless you have caravan really, so just don't fit one.
If your car has lamp failure warning ?, you will need a 7 way bypass box, if not you won't, even if you do have car lamp failure warning this can be left off it will just light up when trailer connected that's all.
Pm if you get any more stuck and I'll dig the neighbours mk2 focus out so I can tell you step by step.
Old 21-10-2009, 10:00 PM
gramsey
gramsey's Avatar
cheers tabetha & dojj but its just not sinking in for some reason. I think if i can see a pic of one wired it might help.
You wouldn't think i was an electrician would ya haha
Old 22-10-2009, 05:16 PM
Just probe the cars wiring to determine the wires needed, after fitting bar solder the wires in, just leave off the indicators till last.
Now looking at instructions for the trailer beeper/indicator flasher, identify the indicator wires each side(will need to lengthen one no doubt), and take a wire feed from here to the beeper unit as per instructions supplied with it, then it will say take the (colour) wire from the beeper unit to pin no(whatever one) of the trailer socket.
The remaining wire from the beeper unit goes to earth, all this in effect does is put the beeper unit between the cars electrics and the tow socket.
It will be from the beeper unit two different colour wires which are hooked onto the indicator wiring(one each side), according to their colour, then there will need to be connected to the socket a YELLOW wire to pin position 1, this if for the left indicator, , it will also have a GREEN wire this is the right indicator from the beeper and goes to pin 4 of the socket.
Download the socket piccie to assist, if still stuck, pm me the wire colour designation from the beeper unit, and I'll draw it out and email you the diagram.
Old 22-10-2009, 07:55 PM
gramsey
gramsey's Avatar
fook me im an electrician and this is battering my head im gona have to take it to an auto spark. tabetha cheers for your help am sure 99% of people could follow it but im bloody useless! cheers
Old 22-10-2009, 08:04 PM
markk
markk's Avatar
you will pnly need 7 way bypass if you have full bulb warning or you have duty cycled rear lamps, and you dont need to cut the roiginal indicators, you just connect onto them.
Old 16-09-2010, 08:01 AM
PMOTH
PMOTH's Avatar
Default Ford Focus Wiring
Hi I've just bought a 1999 Focus estate and I wonder if you can help me.I'm wiring up to tow trailer tent and reading through the answers I see mention of a rear power outlet any idea where I find it?
Old 16-09-2010, 09:23 AM
dojj
dojj's Avatar
Mine was the 12v socket in the back of the load compartment, but mines is a mondeo and an estate so you may need to run a new wire from something. Better still, find an ignition live in the back of the car and tap onto that, assuming you'll have the correct voltage and fuse to be able to run it.
Old 16-09-2010, 09:32 AM
andrewg
andrewg's Avatar
with some of the later vehicles you are better buying the proper kit some times only from the dealer as those smart relays sometimes cause problems, don't think it is required on mk2 focus thou..
Old 16-09-2010, 10:00 AM
Moderator
STeve's Avatar
dead right as all the dealer kits are plug and play
Old 16-09-2010, 10:18 AM
rubinsbin
rubinsbin's Avatar
if you want it done wrong-take to kens in nottingham-IDIOTS!!!!!!!!!!!
100s of customers cant be wrong!!!CAN THEY, REPLYING TO MORE SMALL CLAIMS THAN FITTING-----------
Old 16-09-2010, 02:32 PM
RichieST
RichieST's Avatar
If I remember right you need to whip it over to Ford to have the GEM updated to work with the extra indicators etc.
Old 16-09-2010, 02:45 PM
Moderator
STeve's Avatar
the towing wiring kit from ford include a new uprated hazard switch as I just installed one on my focus last month
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
03-09-2015 10:49 AM
Quick Reply: Focus towbar wiring ????????
