Saggy headlining
Old 13-10-2009, 07:11 PM
Bloomers
Cornish Fasty
Bloomers's Avatar
Default Saggy headlining
noticed the cloth is sagging off mine quite bad now. is there anyway of saving it, or taking it out and fixing properly?
also, how is a sapph bumper supposed to come off? i think the bolts in the sides are just turning
Old 13-10-2009, 07:57 PM
Headlining can often be fixed without removing, just carefully prise back a tiny bit on the edge, and using a long pipe/curtain rod squirt some contact adhesive in there, leave a minute press back the headlining where it's sagged.
The front bumper bolts do corode to the captive inserts, best way is to use a lever and forcibly, but slowly and carefully lever the bits that are secured in the winglets that hang down, as these can simply be beaten back to shape and the triangular captive bits put back in the winglets.
Old 13-10-2009, 08:07 PM
siscossie
3-door moonstone
siscossie's Avatar
Had mine recovered for Ł95 looks like new now, easy enough to do
Old 13-10-2009, 08:39 PM
Rollin Rides
Anyting forsale let me no
Rollin Rides's Avatar
took mine to a local trimmers and they said they would do the headling and c-pillar trims for round a Ł100
not to bad really
Old 13-10-2009, 11:03 PM
Bloomers
Cornish Fasty
Bloomers's Avatar
not stupid money then. its cokming out anyway, so i will have a go myself
Tabetha - ta for the advice, i will have a go tomorrow
Old 14-10-2009, 06:23 PM
Bloomers
Cornish Fasty
Bloomers's Avatar
ok, got the side bits off. do the shitty torx screws in the front have to come out as well? if so, i have a battle on my hands
Old 14-10-2009, 06:42 PM
gibbo frst
gibbo frst's Avatar
they are just height adjusters on the front once the sides are off it should pull off..
Old 14-10-2009, 06:53 PM
Bloomers
Cornish Fasty
Bloomers's Avatar
oh right. ace. i will get cornish on it and see what happens lol
Old 14-10-2009, 07:54 PM
What type of adisive/glue have people used.
Old 15-10-2009, 07:07 AM
I've used HALSTEAD carpet glue(spray), need very little of this, used to use this stuff to suspend 1/2" thick carpet in converted trucks/horseboxes.
Old 17-10-2009, 11:00 AM
Im sure thats the stuff i used last time.Is it in a blue and purple can.When i did mine it lasted about 4 weeks then it sagged again.
Old 17-10-2009, 12:58 PM
No it's a white can with a little bit of red on it.
Vincereese
18-09-2015 12:48 PM
Vincereese
18-09-2015 12:47 PM
3drRich
13-09-2015 07:32 PM
efiste2
28-12-2005 05:29 PM
churchy
26-09-2005 10:56 PM
Quick Reply: Saggy headlining
