Does the coilpack conv handle high boost and rpm?
I run coilpack on a aftermarket ecu, they do seem to give a better spark, and this would tie in, as they came into mass use around the time of lean burn stuff getting common, which need a better spark to ignite ever weaker mixtures.
MSD do a lot of development before they release stuff, and don't do so until 110% convinced any and all problems have been ironed out, but still help in the even of a problem, which I must say I haven't seen with the coilpack conversions, seen some dodgy ford electrics though!!
PassionFords Creator
Hello,
I am not sure what stories you have heard but this system works perfectly well with all power levels. I am yet to experience any complaints from anyone with missfires at any power level.
We did had some issues with dwell time on revision 1, but that was fixed years ago and all drivers sold out into the marketplace upgraded free of charge to revision 1.1
Dont forget that with your P8 you can run the buiilt in drive system with a simple chip data change, although that will render you with no tach drive so you will have to spend some extra on a tacho if some wires and diodes dont work. (They often do)
Hello,
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
