Cheapest and easy brake conversion...
Old 21-07-2009, 02:32 AM
Elvis
Hunka Hunka Burning Love
Elvis's Avatar
Default Cheapest and easy brake conversion...
So, whats the cheapest option for bigger front discs and calipers?
also same for the rear?
Old 21-07-2009, 05:40 AM
Antti O
Antti O's Avatar
https://passionford.com/forum/ford-e...ie-brakes.html
Old 21-07-2009, 08:08 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Front Focus ST 300mm Discs, Mondeo Mk3 Calipers and Pads, 12mm spacer, less than £100!
Rear leave as it is!!
Old 21-07-2009, 09:37 AM
morph
morph's Avatar
Yes don't touch the rears! a bloddy pain if you do!
Old 21-07-2009, 09:41 AM
ROB7656
ROB7656's Avatar
will the above fit under standard rims?
Old 21-07-2009, 11:06 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Has to be at least 16" wheels, or maybe grind a bit off the caliper?
Old 21-07-2009, 11:09 AM
jonesymk2
jonesymk2's Avatar
fiesta st front discs and calipers work well and just some spacers are needed for the calipers,they fit under 15 inch wheels aswell but ive got steels on mine but will check a s2 wheel on for you later and let you know
Old 21-07-2009, 11:16 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Yeah they would fit as they are slightly smaller than cossie discs (5mm IIRC).
Old 21-07-2009, 11:21 AM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
backs aint a pain at all if you know what your doing and using the right parts ,
fronts - as said depends if your wanting to keep standard wheels ,
but cossie 2wd 300mm discs and 4 pots go on with just 2mm spacing
could prob sort you a complete conversion out for you fella,
u you how to contact me
beef
Old 21-07-2009, 11:24 AM
Elvis
Elvis's Avatar
only want big brakes to make the car look hard as fuck
oh and to stop it when the new engine goes in
Old 21-07-2009, 11:31 AM
Antti O
Antti O's Avatar
I have these:
Front:
STD Rs turbo calibers, greenstuff pads, sierra cosworth 2wd discs, braided hoses. I will sandblast & zinc front calibers too next winter.
Rear:
Sierra cosworth 2wd discs & calibers and std rs turbo brake bias valves properly adjusted, braided hoses.
Now i can say rs turbo has some kind of braking power and i can rely brakes. Stopping power is amazing compared to std items. Will fit under rs turbo standard wheels too.
Old 21-07-2009, 01:31 PM
tasos77
rs turbo from Greece...
tasos77's Avatar
rears are 273x10 solid right?
Old 21-07-2009, 01:35 PM
Antti O
Antti O's Avatar
Correct
Old 21-07-2009, 02:02 PM
anvini
anvini's Avatar
Originally Posted by Antti O
I have these:
Front:
Rear:
Hi mate!!
Did you fit sierra cosworth 2wd 283mm Disks with Standards Rs Turbo calipers??
Did you use special brackets for the Standard Rs Turbo Calipers or standard brackets fits ok with sierra cosworth 2wd 283mm Disks??
Old 21-07-2009, 02:10 PM
tasos77
tasos77's Avatar
here you are
http://www.randbmotorsport.co.uk/sho...p?ProductID=49
Old 21-07-2009, 05:48 PM
dangerousbrian
dangerousbrian's Avatar
ive got granada front calipers (off a j reg car) and 2wd cossie discs..calipers were £10 from scrappy and discs and pads were £60..new caliper seals £10.. they do the job..maybe better value mods than this but cant grumble for less than £100
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Cheapest and easy brake conversion...
