Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
Who can "write" diets?
Old 25-06-2009, 01:48 PM
OldDan
OldDan's Avatar
Default Who can "write" diets?
Hello all. I need a diet, struggling at the moment, lost a stone but seem to be hovering around a weight a little. I'm doing the exercise (7 mile a day on the bike, pedalling all way there and back)
Just struggling with diet.
I see a lot of people saying 6 meals a day in smaller portions etc etc. Can anyone give me some help on what to eat, and when? I'm only eating cerial in the morning now - usually skip lunch and then something with chicken fillet for tea. Getting a bit monotonous at the moment to be honest.
Any help -BRILLIANT
Old 25-06-2009, 11:07 PM
Jasesapphy
Jasesapphy's Avatar
I bought a good diet PDF off the net from a personal trainer blokey, I have lost about 3 stone with gym work also, I could email to you.
Old 26-06-2009, 09:03 AM
OldDan
OldDan's Avatar
That would be brilliant mate - is there anything you want for it?
Mr.Meiring (AT) googlemail.com
Old 26-06-2009, 10:29 AM
FAST AS FORD
FAST AS FORD's Avatar
There's nothing really complicated about working out a diet it's just more about what NOT to eat.
However, what you've heard about eating 5/6 small/medium meals a day is definately the way to go with fat loss, providing of course your not over eating at every meal!
For instance, if you looking at around 2500 kcals a day and you have 5 meals then its 500kcal per meal, dont worry about being to specific but keep it ball park and under.
Example:
8.00- raw oats/bran flakes/weetabix with chopped banana and skim milk
11.00- Sandwich made from wholmeal/brown bread, salad (lettuce, toms etc) with tuna/mackerel/sardines/chicken/turkey
14.00- same as above or have wholmeal pasta/brown rice instead of bread (smallish portion of pasta/rice here so carbs aren't to high unless of course you have a very physical job).
17.00- eat a good carb/protein/fat tea, e.g chicken/salmon/turkey/lean mince, with potatoes/pasta/rice (keep these lower if sedate) and as much veg as you can eat.
20.00- if you dont do much in the eve and tend to just watch tv etc then you dont want much carbs in this meal so have a 300g tub of cottage cheese (or if you cant stand the stuff a pint of skim milk) and a handful of nuts/seeds e.g cashews/almonds/brazil nuts/peanut butter/sunflower seeds/pumkin seeds.
If you have slightly smaller portion sizes in the earlier 5 meals you could bung another in at 23.00, again keeping it lowish carb, and making sure the total doesnt exceed you usage. Check weight/measurements regulary and adjust portion sizes to suit.
If you eat this regularly you'll feel less likely to snack (if you have too then obviously fruit is a good option, less so after tea tho)
Keep portion sizes 500 and below (if you estimated to use 2500+ a day you will be in a deficit). Keeping carbs in check and maintaining a steady blood/glucose level by regular eating keeps the body in a higher body fat burning ratio.
If you find your not loosing weight then slightly lower meal portions.
Of course meal sizes are person specific because everyone has different life styles and burns different amount of cals per day depending on their activity, so if your finding that 500 kcal meals x5 is leaving you knackered and weights dropping of you then up the kcal as ideally you shouldnt aim for more than 2-4 pounds per week if your looking to keep the weight off.
The times above are only an example, obviously some people will get up earlier/later and won't be able to eat at certain points of the day due to other activities (mainly work!) Just try and aim for a meal every 3 hours or so when you can fit it around your lifestlye, it soon becomes 2nd nature once you have a basic routine.
As for foods not to eat, well there's the usual suspects, sweets/cakes etc, there's no harm in eating them now and again, just subsitute another part of the meal with equivalent kcal value. Try avoid "whites", bread/rice/pasta, they raise blood sugar levels far quicker than wholmeal/brown and have low levels of fibre. Another "avoid" is sugary drinks as its very easy to get in excess kcal in this way without realising your doing it, obviously waters best but if you want taste then look for low sugar cordials or coke zero and suchlike.
If you have any questions about anything above give us a shout, im by no means an expert but have spent a few years reading up on stuff and practicing what i preach!
Old 26-06-2009, 11:04 AM
OldDan
OldDan's Avatar
That's brilliant! Thanks mate - from Monday I'll give that a good go
Old 24-07-2009, 12:28 AM
xr-stu
xr-stu's Avatar
the only rules i believe you need to follow are a sliding scale of carbs through the day. starting wth shitloads in the morning, and ending with none any less than 6 hours before bed. and eating as close to 0 fat as possible. trimming it out where ever you can by taking skimmed milk, no spread on sandwiches etc. any gram of fat you can cut out, get rid. this includes nuts to contradict what the fella above says. fat is fat, and nuts are high in it. some being aminos but still. when your trying to lose weight, dont eat fat.
and try and do medium intensity cardio for at least 45 mins per session on an empty stomach.
Old 24-07-2009, 12:21 PM
farkkraf
farkkraf's Avatar
Are you doing 7 miles everyday? If you are then you may be overworking your body. Incorperate rest days into your weekly training plan and you will probably start seeing progress again. I found a website called shapefit helpful when learning about nutrition, there are sections on every aspect of a training, nutrition and also have interviews with professional fitness models which gives details on their training schemes and meal plans
Old 24-07-2009, 12:29 PM
farkkraf
farkkraf's Avatar
You will lose fat following xr-stu advice but reducing your fat intake to near 0 will leave you feeling lethargic and generally really crappy all the time. On top of that you will start to get cravings which will get increasingly worse, after a week or so you will probably start binging and thinking about food all the time. This will be due to your body craving fat and when you do eat some it will stick to you like super glue.
jay030787
05-08-2015 09:28 PM
Paul Eggleton
24
31-08-2006 06:11 PM
Lee Reynolds
49
05-07-2006 07:22 PM
Paul Eggleton
17
09-01-2006 08:19 PM
M Brian
11-10-2004 02:40 PM
Quick Reply: Who can "write" diets?
