YB exhaust manifold flanges
Old 23-05-2009, 10:58 PM
markk
markk's Avatar
Default YB exhaust manifold flanges
Anyone know wnyone who make a bare cylinder head exhaust manilfold flange?
i want to make my own manifold but cant find a flange to start with.
Old 24-05-2009, 01:20 AM
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
ojz engineering in lincolnshire , hes got a laser cutter and can make anything you want just send him a gasket to copy , also sells merge collectors and mandral bends and straight pipe in 304 and 321 stainless . he make the best exhaust manifolds ive seen but hes happy to supply you with the parts , check the website out
hope that helps
cheers paul
Old 24-05-2009, 09:47 AM
markk
markk's Avatar
i do know of a laser cutting company, but, the std gaskets are four pieces, and would like it all in one section, someone must have them on the shelf somwhere for nasp engines.
Old 24-05-2009, 07:30 PM
PGT
PGT's Avatar
you could spray a coat of paint onto a cast one and whilst still wet stick it to the flat plate you are going to use as the flange and the paint left on the plate is your template!
Old 25-05-2009, 03:03 PM
GARETH T
GARETH T's Avatar
what material you thinking of making it from?
the problem with a flange made in one is the expansion
Old 25-05-2009, 09:20 PM
markk
markk's Avatar
im going to be using stainless tubing, hmmmmmm might just have the four flanges profiled.
Old 26-05-2009, 07:56 PM
GARETH T
GARETH T's Avatar
keep us informed on his it goes! i was going to have a bash a few years ago, but didnt find the time!
Old 26-05-2009, 09:04 PM
zetaboostboy522bhp
you will be alrite with a mild steel 13mm thick 1 piece flange , use mild steel for the flange as its better for expanding than stainless and yes you can weld stainless to mild steel
heres some ive done in the past
Old 26-05-2009, 09:31 PM
markk
markk's Avatar
cool
cheers for the info exhaust looks good, did you use the tubes as stainless and just the flange as mild steel ?
Old 26-05-2009, 09:44 PM
zetaboostboy522bhp
cool
yes mate , 304 stainless tube and mild steel flanges
Cosnada
07-01-2016 05:30 PM
dalmarshall
Ford Classics & Vintage
01-10-2015 06:46 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
caprixpack
25-09-2015 07:53 PM
Quick Reply: YB exhaust manifold flanges
