Zvh turbo engine
Escort Cabriolet Owner
Zvh turbo engine
full zvh turbo engine + gearbox + ecu's NO LOOM
ok well its a 1.8 zvh
head has had a fair bit of work done
after market cam (unsure of make )
double valve springs
ported and polished & widened ports
Bigger valves
very clean
removed valves etc to fully check head (will be built back up but recommend regrounding them in again)
decomp plate
bottom end complete had sump off to check bottom end which is very clean (recommend new sump gasket )
oil return needs a bit of work as previous owner/maker has make hole a fraction to big for treaded pipe that is being used and then gasketed in place i removed to sort it but never got round to it
then just need rebuilding
but comes with
head
block
inlet
outlet
turbo ( smoking needs rebuild)
if needed
ecu's
rst rad
standard i/c
everything to run it in a escort rst apart from loom
looking for £500 ono for this
also got extras of a
set of blue samco boost hoses
pace double capacity intercooler
full stainless exhaust
again all to fit a escort rst looking for £700ono for engine with all of the above
on ebay aswell with £500 reserve and 700 bin without all the above extra items so if interested please pm me thanx alain
Bigger valves
very clean
decomp plate
but comes with
head
block
inlet
outlet
if needed
ecu's
rst rad
standard i/c
big_Rad
15-09-2017 09:36 AM
