should rear coilover springs be harder or softer than fronts?
Old 03-02-2009, 08:46 AM
Roosie
500bhp Cosworth in making
Roosie's Avatar
Default should rear coilover springs be harder or softer than fronts?
not sure just bought some rear coilovers for track have some already on front.
should rears be hard or softer?
Old 03-02-2009, 08:48 AM
olek
olek's Avatar
depends on the car doesn't it?
usually is softer at det back with 2wd and 4wd, but fwd usually has stiffer springs at the back.
i'm running 550 lbs at the front, and 350 lbs at the rear on my trackday 2wd sapphire. gaz gold coilovers. well pleased with that setup.
Old 03-02-2009, 08:49 AM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
softer.....it's a breaking thing....
Old 03-02-2009, 08:55 AM
Luca
Lukesville
Luca's Avatar
I run 350 upfront and 550 up the rear on the Festa
Old 03-02-2009, 09:15 AM
pete mcrash
there goes my theory.........
Old 03-02-2009, 09:28 AM
Garage19
Garage19's Avatar
Totally depends where your weight is distributed and where your drive comes from.
Old 03-02-2009, 09:41 AM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
not wrong, it depends on what wheels are driven
Old 06-02-2009, 12:21 PM
Roosie
Roosie's Avatar
What size rears? 12"?
Old 06-02-2009, 12:41 PM
Roosie
Roosie's Avatar
ive got 500lbs up front so ive just ordered 350s for rear
Old 06-02-2009, 12:46 PM
Luca
Lukesville
Luca's Avatar
Sounds about right, mine handles well in reverse so for Rwd i reckon thts about right, BUT if not then its not too dear to play around with different spring rates
Old 06-02-2009, 02:16 PM
alanfordtw-15
alanfordtw-15's Avatar
if you have rwd and want to break traction easily(drifting) make them harder at the back.
if you have rwd or 4wd and want to do good drag launches without wheelspin make them softer at the back, to push more weight on the back wheels.
for a good handling rwd/4wd car have the backs a small bit softer than the front
just my experiences with setups
luca is spot on about fwd
Old 06-02-2009, 02:18 PM
pee vee
pee vee's Avatar
Luke, whats yours like on the road? as that is pretty huge spring rate you are running !
Old 06-02-2009, 02:38 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
I hope it is for a track only Sapphire, or you're in for a NASTY shock (literally) . Do you have any fillings? Don't worry if you have, because you won't for much longer .
Old 06-02-2009, 02:47 PM
olek
olek's Avatar
from what i can remember it's 8" up front and 12" at the rear.
Old 06-02-2009, 03:23 PM
Roosie
Roosie's Avatar
yes mike track only
Old 06-02-2009, 03:26 PM
Luca
Lukesville
Luca's Avatar
Il be totally honest it rides better than with the old set up which was half that.
Id also go as to say I may increase the rear rates by 50 and see how it feels. As for Road its not harsh in the slightest which I agree i thought it would be.
Old 06-02-2009, 04:05 PM
Mike Kerbey
Mike Kerbey's Avatar
This is correct, its all about where you want the weight to shift when your on and off power, braking.
If the back is to soft, then on power, exiting a corner it will generate understeer, etc etc
Old 06-02-2009, 08:43 PM
rstdave
rstdave's Avatar
Running 350/450 split on my erst on advice from a reputable source......would hardly say it's a 'nice' ride on the road tbh but then it's on track where i want the car to handle so it's not a concern! Haven't had the chance to try em yet on track so can't confirm how the car handles.
jessie_rs
11
03-06-2019 04:57 PM
C2 MAK
20-08-2015 09:46 PM
sierra cossie
07-08-2015 12:17 AM
Quick Reply: should rear coilover springs be harder or softer than fronts?
