Replacing clutch cable on m reg transit
Old 20-01-2009, 10:54 AM
SelbyRST
4x4 SAFF
SelbyRST's Avatar
Default Replacing clutch cable on m reg transit
The clutch cable on the work van snapped this morning, just manged to get a new one.
All i was wondering is, when fitting the new one, do i need to adjust the rachet on the pedal or anything, or will it sort itself out and just a case of putting the new one in.?
Old 20-01-2009, 11:35 AM
DangerousBryan
DangerousBryan's Avatar
it will sort itself out when you have pressed the pedal a few times mate. the hardest bit is getting the grommet back in the bulkhead.
Old 20-01-2009, 11:58 AM
SelbyRST
4x4 SAFF
SelbyRST's Avatar
Cheers mate, yeah iv noticed that might be abit difficult! ill go get on with it then.
Old 20-01-2009, 01:10 PM
999's Avatar
m reg will have the self adjuster
Old 20-01-2009, 02:19 PM
SelbyRST
4x4 SAFF
SelbyRST's Avatar
Yeah its got the self adjuster. I fitted it about ten mins ago, it wouldnt go into gear, so pressed it a few times to see if it would adjust and then it snapped again .
Any ideas why it would have snapped lol, before i waste another 16 quid, then again they might give it me free as i only got it this morning
Old 20-01-2009, 05:49 PM
DangerousBryan
was the clutch heavy? might need a new clutch. they usually strip the teeth off the self adjuster before they snap the cable,did you have it routed properly?
Old 01-11-2011, 08:32 PM
ricky0121
boss man
ricky0121's Avatar
you ok mate did you sort your clutch cable out ive got same problem i changed cable 2day but my pedel is still on the floor have u got any ideas plz mate
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
yatta
21-05-2016 10:31 PM
Flateric_2002
15-09-2015 08:41 AM
Bransby
14-09-2015 08:54 PM
NC53
13-09-2015 03:05 PM
Quick Reply: Replacing clutch cable on m reg transit
