External fuel pumps
Old 11-01-2009, 10:59 PM
Sarge
Sarge's Avatar
Default External fuel pumps
Has anyone installed an external fuel pump on a Ford Mondeo or SVT Contour? If so what kind of results have they had or differences if any?
Old 11-01-2009, 11:05 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
To achieve what?
Old 11-01-2009, 11:11 PM
Sarge
Sarge's Avatar
Well I have a 2000 SVT contour modded with a 3 liter turbo and upgraded trans but it has a problem with eating fuel pumps and I am tired of digging through the interior and dropping the tank as this is the third one and just wondered for modularity purposes if and external tank was worth the time. Grant you it is not a machine that pushes huge HP but it is a thirsty bugger and I am looking at all options of upgrading and this one was a possible refit/solution. Yes I know about the aftermarket lines of pumps and refit units I am just curious about out of tank applications. Thanks for the quick reply by the way
Old 11-01-2009, 11:17 PM
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
why is this in the Restorations, Rebuilds & Projects section??
Old 11-01-2009, 11:25 PM
clarke5700
clarke5700's Avatar
i cant see how a bigger engine will kill fuel pumps?? the pump its self will have to work harder but will only pump as much as it can this will not burn it out?? i think you problem is else where mate
Old 12-01-2009, 02:48 AM
Sarge
Sarge's Avatar
engine did not cause it to go out...it is the way the strainer and screen on bottom of assembly is made...they revised it on the cougars after the contour phased out because the screen and strainer would catch debris and clog up causing it to strain the pump...stations around here dont really filter their fuel well and there tanks get rubbish in them and it gets passed along to the consumer. sorry I consider this a rebuild that is why I posted it here...probably an unwise choice now that I look.
JK12
33
26-04-2021 12:09 PM
27-10-2015 04:55 AM
07-10-2015 03:43 PM
tib2220
14-09-2015 12:33 PM
RSBryden
06-09-2015 08:39 PM
Quick Reply: External fuel pumps
