Clutch change on a vauxhall Zafira?
Old 09-10-2008, 10:32 AM
hai07222
hai07222's Avatar
Default Clutch change on a vauxhall Zafira?
How hard is it?. any special tools needed?
thanks!
Old 09-10-2008, 12:33 PM
Paul_Painter
Paul_Painter's Avatar
Hello Mate
It depends what engine it is? Most are straight forward. Obviously the smaller engines are generally easier.
Normal principle of removing driveshafts etc. Then support the engine and remove the box.
Lets face it, a clutch is never a nice job, but they aren't too bad!
Old 09-10-2008, 01:45 PM
hai07222
hai07222's Avatar
Ok thanks for that
Old 09-10-2008, 04:08 PM
cossie604
cossie604's Avatar
As above mate, they are a doddle. Undo the steering intermidiate shaft from the rack, cable tie the radiator to the slam panel, undo power steering pump leccy connections, remove battery and tray....underneith the car now, remove exhaust front section, remove the lower subframe....after that you'll be amazed at how much room there is to work with and it all becomes self explanatary at that point
yatta
21-05-2016 10:31 PM
IainRS1700T
25-09-2015 06:44 AM
talon1
15-09-2015 10:27 AM
Flateric_2002
15-09-2015 08:41 AM
marky_g
12-09-2015 04:26 PM
Quick Reply: Clutch change on a vauxhall Zafira?
