How do you adjust Coilovers?,do you jack the car up and turn an adjuster.......
Old 28-08-2008, 02:33 PM
Mr Brannen
Mr Brannen's Avatar
Default How do you adjust Coilovers?,do you jack the car up and turn an adjuster.......
also is there height markings on the shockers so that you can keep one side level with the other,just thinking about it there and I didnt know the answer
Old 28-08-2008, 02:41 PM
Doug
Doug's Avatar
You can turn the adjuster with the car on the floor.
If its on car in your sig set the rears to about 3-4 clicks otherwise will be to harsh for road use and set fronts to about 6
To set the ride hight on the adjustable platforms use a tape measure from the lowest thread on the coil over to 1st platform so car is level thats a quick guide .
Regards Doug .
Old 28-08-2008, 02:44 PM
Mr Brannen
Mr Brannen's Avatar
thanks matey
Jim Galbally
Jim Galbally's Avatar
heightwise? you'll want to jack it up to remove the weight on the springs else itll be really hard to turn, and check there's normally a locking screw/pin in the adjuster so make sure yuo undo this first (been there, done that )
Old 28-08-2008, 02:51 PM
rst in breaking
rst in breaking's Avatar
as jim says, i jack the car up to release the load from the spring then undo the grub screw and set height
Old 28-08-2008, 02:57 PM
Luca
Lukesville
Luca's Avatar
Ideally all 4 corners should be at different heights..
The reason for having the adjustabilty is so you can have the car corner weighted so that the car is euqually ballenced on all four corners.
otherwise a ruler will suffice
Old 28-08-2008, 02:58 PM
Jim Galbally
^^ what he said
Old 28-08-2008, 03:00 PM
rst in breaking
how much is it roughly to get a car corner weighted?
04-01-2024 02:36 PM
The Underdog
29
07-09-2015 09:49 PM
mattman1234
14-08-2015 10:05 PM
adam151082
11-08-2015 04:50 PM
Quick Reply: How do you adjust Coilovers?,do you jack the car up and turn an adjuster.......
