How easy to change a rocker cover gasket?
Cossiemodo
Bought one off eBay, not sure if I can be arsed taking it to my mechanic, or fitting it myself? Is it a piece of piss to do??
It's one of those steel & rubber ones. I bought half moons too.
Just to add put a thin smear under each front cap as well, as they leak here, and trim the gasket where it butts up against the caps,to make sure the hole is perfectly in line before applying half moon gasket sealant, I use gasket just dabbed on the recess the half moons sit in just to hold them there.
As said sounds like a COMETIC these are reuseable FOAM ALLOY.
That's just a spare oil reserve in case you get low!!
Not seen that bad since I did a shonky V6 omega, they're famous for that.
Did you get it all sorted now ?
Cossiemodo
Adam Graham
06-09-2015 06:04 AM
rog
04-09-2015 07:24 AM
