Focus coolant temp sensor--Where is it??????
Old 13-05-2008, 05:50 PM
JamesH
JamesH's Avatar
Default Focus coolant temp sensor--Where is it??????
On a W reg 2000 1.6 Zetec black top
Where is the coolant temp sensor guys? Its the same thermostat housing as the silvertop but without the top tapped for the coolant temp sensor, so where is it? Is it inside the housing?
If you want to replace it do you have to replace the whole housing? And if so where are the wires/how are they located?
The fans are NEVER cutting in and temp gauge won't EVER go higher than exactly halfway so I think its this
Old 13-05-2008, 07:44 PM
RichieST
RichieST's Avatar
pretty sure its between 2nd and 3rd plug, or this could be the case with the 1.8/2.0.
Does it have a/c? If so, put that on and the fans should cut in, at least you know they work. My focus 1.6 gauge never ever budged from half way either, and the fan would only cut in on the hottest of days being sat in traffic. Dont worry about it unless the gauge creeps past half way.
Old 13-05-2008, 07:52 PM
sebspring
Winker
sebspring's Avatar
as he says. it si measured on teh back of the head or something like this.
put the a/c switch on or put the direction fan to windscreen with fans on and that switches it on as well
Old 13-05-2008, 08:01 PM
RichieST
RichieST's Avatar
only the post-facelift focus's will do this
Old 13-05-2008, 09:04 PM
JamesH
JamesH's Avatar
Well it was boiling over and the gauge still only read halfway which has led me to this conclusion!
Its a very early (W) Focus, 1.6; so is it on the back of the head then?
Old 13-05-2008, 11:18 PM
cjwood555
cjwood555's Avatar
yeah as above it's a Cylinder Head Temperature Sensor rather than coolant temp sensor....
the guage is driven over the CAN bus / SCP link and only is programmed to stay in the middle once up to temperature unless the temp varies dangerously. This was apparently because there was a large number of complaints of 'high running temperatures' in foci, despite the lack of a scale on the guage!
Ok so that probably doesn't help, but a failed CHT would probably result in rough running when cold. Have you checked fuses and relays? Also worth testing the fan itself directly off the battery....
Chris
Old 15-05-2008, 04:07 PM
RichieST
RichieST's Avatar
I'd firstly get the thermostat and expansion tank cap changed. Does it boil over all the time, or just when its sat idling?
Old 15-05-2008, 04:23 PM
JamesH
JamesH's Avatar
Just when idling, as obviously when moving there is air going through the rad
I think stat is fine as once warm I felt the pipe and water was going through
Old 05-06-2008, 12:08 PM
Zetecfiesta
Zetecfiesta's Avatar
did anybody find the location of the coolent head temp sensor as im looking for it now and cant find it!
Old 05-06-2008, 06:55 PM
cjwood555
cjwood555's Avatar
as above, it's a head temperature sensor, not a coolant temp sensor - it's between spark plugs 2 and 3....
Old 26-10-2009, 02:57 PM
mark.evs
newbie
mark.evs's Avatar
first i'd like to say hi as im new to your site, looks great and will probily be on here a bit.
I'm searching for this invisable sensor too, Its for an 1800 black top zetec 1998. its not between plugs 2 and 3 in the cam cover and not in the stat housing. it's been on diagnostic maching and it found a fault with the 'engine management cooling temp switch'. any ideas? it's not under the cam cover is it? many thanks.
Old 26-10-2009, 03:16 PM
Csm
Csm's Avatar
Under the cam cover matey
Old 26-10-2009, 03:19 PM
mark.evs
newbie
mark.evs's Avatar
cheers, the haynes book showed it being in the cover. it's been driving me nuts for weeks. Thanks again.
Old 27-10-2009, 10:45 AM
mark.evs
newbie
mark.evs's Avatar
it's not under the cover either. any other ideas?
Old 17-02-2012, 02:59 PM
richard21172
richard21172's Avatar
did the original problem get fixed ? i have the same issue on a Y reg focus
Old 17-02-2012, 05:47 PM
JamesH
JamesH's Avatar
As far as I know, changing the thermostat fixed the problem!
Old 29-04-2017, 11:34 AM
Glacken52
Glacken52's Avatar
Default Coolant sensor location
the sensor is on the side of the head underneath the intake manifold so u have to take off the manifold to get to it unless your intake is in the front u might be able to get beside it and squeeze your way to the sensor
Old 29-04-2017, 11:42 AM
RichieST
RichieST's Avatar
I'd say after 5 and a bit years he probably isn't still under the bonnet looking for it....
Old 29-04-2017, 11:46 AM
t230
t230's Avatar
sure it aint fastlife91?
Old 22-12-2017, 01:42 AM
GVK.
GVK.'s Avatar
Lol, some zetecs had the CHT sensor in the back of the head, behind the alternator.
Old thread but someone may find it useful
Old 22-12-2017, 07:26 AM
Was the sensor in the head near the spark plugs for the temp gauge??
Old 22-12-2017, 10:04 PM
GVK.
GVK.'s Avatar
Was on the smaller zetec se Glenn.
Old 10-01-2018, 04:29 PM
Prefect57
Prefect57's Avatar
Hi All
As a newbie I have a duretec ST engine in my 2002 and Im interested to know were all the sensors are as the temp gauge hardly moves of the stop when running but hits half way mark when standing , went to ford dealer today not much help Haynes manual not much better.
I can see a sensor on the thermostat housing and a knocking sensor on the back of the block which has same colour wiring at the sensor on the housing .
Bought new thermostat housing which when I opened didn't have the hole for the sensor but was the right one from the supplier with the details I gave him from the reg.
Can any one advise and give some help on this one as Im going on a road trip across Europe end of the month
Appreciate it
many thanks
Old 10-01-2018, 04:30 PM
Prefect57
Prefect57's Avatar
Smile Virgin
a Virgin at 61 years old hmmm
Old 10-01-2018, 05:52 PM
big_wasa
big_wasa's Avatar
If this is an st170 The rocker cover may say Duratec, but it isn’t. It’s a posh Zetec.
The dash doesn’t have any sensors. All the info is sent to the dash from the ecu via a coms network ie M bus and can bus.
The little oil temp and pressure pod is also driven by ecu and the info is a total fabrication.
Unless you find a good used stat housing they are all coming blank now. But the boss should be there so you can drill it out for the push fit sensor.
Prefect57 (10-01-2018)
Old 10-01-2018, 06:47 PM
Prefect57
Prefect57's Avatar
Smile
Thank you for the feed back much appreciated
DixieTheKid
11
06-06-2020 11:20 AM
Botts
22-09-2015 02:04 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
wheelwizardrefurbs
05-09-2015 10:52 AM
Ben26
03-09-2015 07:55 PM
Quick Reply: Focus coolant temp sensor--Where is it??????
