How much would you give for this YB engine?
Old 21-12-2007, 06:36 PM
McGoo 69
McGoo 69's Avatar
Default How much would you give for this YB engine?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=160191764845
im intrested in buying this as it is fairly local to me. If i can get it at the price ive discussed with the seller im on a winner.
How much will you give for it? And how easily do you think it can be fixed?
I have a spare T3 turbo in my garage
The seller has the broken lugs of the block to mount the gearbox, im sure these could simple be welded back on and retapped?
Can the crack in the inlet manifold be welded back up?
either way its going to need a full rebuild but if the broken parts can be welded up surly it will be a good cheap engine as its quite a new build.
Thanks Matty
Old 21-12-2007, 06:42 PM
McGoo 69
McGoo 69's Avatar
oops was ment to go in general discussion
Old 21-12-2007, 09:10 PM
Kelv
Almost there!
Kelv's Avatar
Damage to block, cracks to head - personally i wouldnt bother with it.
Old 22-12-2007, 08:46 AM
sailorbob
sailorbob's Avatar
As above, a lot of the engine is damaged and only good for spares. Blocks and heads are cheap enough to not need to bother repairing damaged ones. The only reason that I can see for buying that lot is if you want to build a Westie as it has some nearly new parts on it.
Tim Wharton
30-08-2015 05:46 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
IAN RS2k
18-08-2015 07:51 PM
Bailes1992
16-08-2015 07:14 PM
knight19770
04-08-2015 12:36 PM
Quick Reply: How much would you give for this YB engine?
