Mappable ECU's-which one!?
Old 15-12-2007, 07:36 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Default Mappable ECU's-which one!?
As title.
Engine rebuild is finished and I'm running it in on the original Stage 3 Superchip (which makes it run like a dogs dinner!!!) and a set of Dark Greens.
It will be running a T4 roller bearing turbo and 1000cc injectors at some point and needs a mappable ECU, I'm thinking an Autronic SM4 at the moment. Any advise otherwise!!????
Cheers,
Old 15-12-2007, 08:45 PM
rapidcossie
rapidcossie's Avatar
What does Alan think?
Old 15-12-2007, 10:31 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Where do you think I got my idea from!!
LOL
He is a fookin legend!
Didn't mention a model, but looking at it, I think either an SM 2 or an SM 4 should sort me out.
What are you running Euan?
By the way, I'm seeing more of your car now than you are!! LOL
Here's a reminder!!
Still looks the dogs!!
Sorry for the shit phone pic!!
Old 16-12-2007, 12:19 AM
Mr.Ford
Mr.Ford's Avatar
I've heard some good things about SECS ECU's....
Old 16-12-2007, 12:30 AM
RWD_cossie_wil
RWD_cossie_wil's Avatar
whats wrong with an L8 or P8 ? They are both "mappable"
Old 16-12-2007, 01:03 AM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
i run SM4 totally happy with it
Old 16-12-2007, 01:20 AM
JHS
JHS's Avatar
Stick with whatever your tuner recommends...
Old 16-12-2007, 06:30 AM
NEIL A
NEIL A's Avatar
Would say go with what Alan thinks if he is going to map it. I know he likes the Autronic stuff and is good at mapping it. He is also trying the Colins ecu out on my car and from what he has said thinks its a good bit of kit and is plug and play.
Bonus is if you go for Autronic he will have a good frew maps to work from as it sounds like you will be similar spec to Euan.
Old 16-12-2007, 03:01 PM
Gatecrasher
Not welcome...
Gatecrasher's Avatar
T6
Old 16-12-2007, 03:18 PM
Cosworth Bassie
Cosworth Bassie's Avatar
I'm using ADAPTRONIC
Can handle the std triggering and sensors, and a very good self learning mode.
Also a lot of features.
Regards,
Bas
Old 16-12-2007, 03:43 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Cheers for the help!!
I think I'll stick with the Autronic (just toss a coin for SM2 or SM4!!) as Alan mentioned it first, and as you say Neil, he'll be mapping it and has some good info to work from!!
Old 16-12-2007, 03:45 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
LOL! You should try driving mine at the moment then!!
Old 16-12-2007, 03:47 PM
Mark Shead
Mark Shead's Avatar
The SM2 is a older unit the SM4 is the latest unit and has many more functions.
Mark
Old 16-12-2007, 04:04 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Cheers for that!
4 it is then!
Old 16-12-2007, 04:10 PM
rapidcossie
Just get Alan to get you and SM4 from Mark
My car looks bogging in that pic
Old 16-12-2007, 04:14 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Will do!!
Your car does need a bit of a spruce up!! LOL
Old 16-12-2007, 04:23 PM
rapidcossie
so will yours if you keep slagging mine
Old 16-12-2007, 04:38 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Old 17-12-2007, 07:07 AM
Yura
Yura's Avatar
Default Re: Mappable ECU's-which one!?
Superchip made a good chips? Your chip have closedloop? Babyboard is standart?
Thanks!
Old 19-12-2007, 06:57 AM
fehlbie
fehlbie's Avatar
I have been runing a Autronic SMC now for 4 years on my Escort cosworth and runs like a factory car. What more could you ask for.
Old 19-12-2007, 09:06 AM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
What sort of price was it, if you don't mind me asking??!!
Old 19-12-2007, 12:18 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Buy it from Mark, the back up you get is second to none!
Old 19-12-2007, 12:21 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
What does it cost to fit it all and map it etc??
foreigneRS
Testing the future
foreigneRS's Avatar
that's not a very good advert for the RP Lab ecu Mike
Old 19-12-2007, 12:30 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Is the RP Labs one good, Not heard of it before now?
What sort of price are they, somewhat cheaper than an Autronic I presume!!?
Old 19-12-2007, 12:40 PM
Mike Rainbird
Caraholic
He's already made up his mind and his tuner wants him to get Autronic .
The RP labs one only works out as a competitive package if you already have an L8 ECU, whereas the Escort is P8, so he would have to buy an L8 and then have that converted.
It still then doesn't have the number of mapping points (or all the features) as the Autronic, which runs a 36-1 pulley like T6 etc.
I just didn't see the RP labs one as being applicable in this instance (just like despite being a T6 man, I didn't think this was applicable in this instance either ).
His tuner is familiar with Autronic, his tuner has maps for Autronic, his tuner suggested Autronic, so given that, I think that Autronic is the way to go in this instance . Despite what some think, I try to be as objective as possibe...
Mike Rainbird
Caraholic
ASK ALAN .
Old 19-12-2007, 12:46 PM
foreigneRS
Testing the future
foreigneRS's Avatar
Mike Rainbird
Old 19-12-2007, 02:04 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
ASK ALAN .
Yeah I will!
Better take my cheque book!
Old 20-12-2007, 10:20 PM
rapidcossie
Mapping at AVA is cheaper than most places as Alan only charges per hour on the rollers.
Mark was 350 to map mine on the road.
Old 21-12-2007, 10:00 AM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Need the brain replaced first though!
Old 21-12-2007, 10:23 AM
NEIL A
NEIL A's Avatar
I would say get Mark/Rod to fit it as they have done loads so will be alot quicker then stick a base map in to get you up the road then get Alan to map it as its his engine.
Old 21-12-2007, 10:55 AM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Do you know if Alan likes Mtech ecu's. Getting a 'mixed' response on those!
Old 21-12-2007, 11:03 AM
rapidcossie
Alan can map anything he is given but in all honesty mate your better going with something he has a good bit of experience with.
It means he can utilise all the special features of said ECU and reall y get the best out of the engine.
Mine was the first Autronic he has mapped and he is still finding new things on it everytime he explores the menus
Old 21-12-2007, 12:13 PM
NEIL A
NEIL A's Avatar
As Euan says easyer to go with something the mapper knows , i know he was just getting to grips with the colins ecu as he never got much help from colins untill he got a good contact there
Old 21-12-2007, 02:24 PM
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
I'll be glad when i get it back up there!
mark94
10-10-2023 06:52 PM
griffo69
04-10-2015 11:58 AM
R4N SS
Ford XR Parts For Sale
15-09-2015 03:38 PM
DixieTheKid
14-09-2015 09:04 PM
Tank Mike
14-09-2015 03:56 PM
Quick Reply: Mappable ECU's-which one!?
