Dizzyless cam sensor (mounted in cam cover)
Old 05-12-2007, 11:45 AM
Bomber
Bomber's Avatar
Default Dizzyless cam sensor (mounted in cam cover)
Anyone tell me the Ford part number for these? I was under the impression they are a Zetec Cam Sensor?
Thanks,
Mark
Old 05-12-2007, 11:48 AM
ian sibbert
ian sibbert's Avatar
Finis no 6602999 and yes it is the zetec cam sensor....
Old 05-12-2007, 11:54 AM
Bomber
Bomber's Avatar
Cheers!
Old 05-12-2007, 05:00 PM
- Sim -
- Sim -'s Avatar
what is all needed for usage
sensor
reworked cam cover
reworked inlet cam
any electronic changes needed?
Old 05-12-2007, 05:41 PM
MaxCos
MaxCos's Avatar
have a look on here:
https://passionford.com/forum/viewtopic.php?t=194126
Old 05-12-2007, 06:47 PM
sailorbob
sailorbob's Avatar
If you want to go distributor-less on a BT Escort Cosworth you can use the ST cam sensor (it fits where the distributor goes) and save yourself the hassle of modifying the cam cover.
Old 05-12-2007, 06:57 PM
kjc300
kjc300's Avatar
How have you wired it mate?? As I thought it was hall effect and worked differently??
Old 06-12-2007, 05:20 PM
- Sim -
- Sim -'s Avatar
Originally Posted by MaxCos
Sorry, but only Gold Members or/and Traders can read topics in this forum.
Click here to select a group to join. You will need to pay a subscription fee.
Old 06-12-2007, 06:07 PM
ian sibbert
Having converted to coilpacks i decided to completely remove the dizzy. Removing the dizzy meant moving the phase sensor to the cam cover Grp A style. The removal of the dizzy required an oil pump drive as well.
Firstly i made an oil pump drive by cutting the dizzy in half and machining the shaft to take a bearing
Then made a housing to fit in the block
Then pressed the two bits together
To give
And finally fitted to the engine
To fit the phase sensor in the cam cover you need to machine the cover to take the sensor holder
I then got the sensor, holder and phase sensor trigger. Available from Mountune or Zoo.
The sensor and holder fitted to cam cover
The cam requires machining to take the trigger
Thanks to Martin@Reyland for that bit of machining
The trigger then bolts into the end of the cam
From B9KOS's tech essay....
Old 07-12-2007, 07:37 PM
sailorbob
sailorbob's Avatar
It is Hall effect.
Old 01-12-2010, 07:53 PM
xr3-2-rsturbo
xr3-2-rsturbo's Avatar
at what angle are the cam timing lobes on the late escort cossie... EECIV??
Dr. Ickxs
15-09-2015 10:15 PM
BRAMMER
14-09-2015 08:52 PM
Chopshop85
12-09-2015 06:42 PM
rog
04-09-2015 07:24 AM
StephTell
02-09-2015 06:31 PM
Quick Reply: Dizzyless cam sensor (mounted in cam cover)
