Escort Mk6 Brake upgrade.
Old 29-09-2007, 10:25 AM
spiceboy
spiceboy's Avatar
Default Escort Mk6 Brake upgrade.
Hi,
I have been told I can fit Escort cosworth 4x4 Calipers and discs to my mk6 escort zetec? Does anyone know if this is true?
Old 29-09-2007, 10:57 PM
lukemakepeace
lukemakepeace's Avatar
i dont but would love to do it too
Old 29-09-2007, 11:30 PM
markeyboy
markeyboy's Avatar
yes ya can m8,
iirc you will need to pack out the calipers away from the hub, you can do this with either washers or making a spacer plate, i think you will need a different banjo bolts, and longer caliper mounting bolts.
iv got a set of 4 pot saph cossye calipers to put n my mk6 when i get round to it
Old 01-10-2007, 03:23 PM
Ollie MK5 Turbo
Ollie MK5 Turbo's Avatar
Yes it can be done
Old 02-10-2007, 10:37 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
yes, it can be done
as said, you need to space the calliper about 4 or 5mm from the hub, i used 3 10mm washers i think.
i also used the braided brake lines that came on them, but needed a female/female adaptor for them to fit.
Old 02-10-2007, 11:23 AM
trig_112
trig_112's Avatar
I have a set on mine.
I used the mondeo mk2 V6 calipers though as they were cheaper.
The caliper carrier has to be spaced out from the hub by 5mm, CVH head bolt washer is the perfect thickness, but needs to be opened out to allow the caliper bolt through, as does the mounting holes on the hub.
Use escort cosworth discs with them and they will be spot on. I have mondeo hoses on mine too, not got round to braided yet.
Old 02-10-2007, 12:19 PM
Yes easy mod, depending on the car a good mod, for cossies, the escy/sapph 4wd are hopeless, so better they find a new home!!
Old 02-10-2007, 03:56 PM
spiceboy
spiceboy's Avatar
Hi
Thanks for the advice all!!!!
Do I need longer bolts if im packing them out with washers? or can I just use the bolts on my mk6?
Cheers.
P.S. to those who have fitted them do they make a big difference?
Ta
Old 04-10-2007, 09:42 AM
trig_112
trig_112's Avatar
I just used the bolts that came with the carriers/calipers, there has been no problem for the last year and a half
And do they make a difference, in a word, yes.
Best mod I have made on my car
Old 05-10-2007, 02:34 PM
spi escort gti
spi escort gti's Avatar
Default escort gti mk6
hi i have a escort gti and im wanting to fit rear discs BUT i have abs
all round so what do i need
and im wanting to have bigger discs and calippers to the front what do i need more info the better
PICS TO
thanx ste
Old 03-08-2010, 04:53 PM
jghs83
can you smell purple?
jghs83's Avatar
Location: normally dewsbury west yorkshire, but i could wake up anywhere!
so will mondy st24 discs/calipers/pads bolt straight on then just by spacing the caliper out or does the discs need swapping out for 4x4 cosworth ones?
Old 25-04-2020, 07:59 PM
Josef Camilleri
Josef Camilleri's Avatar
Default Escort mk 6 with Mondeo mk 1 disc brakes
Hi I just upgraded my front brake setup on my Escort mk6, fitted Mondeo Mk1 calipers was a straight forward fit however I had to enlarge the hub holes and had to space the hub from the discs with a washer on each stud as the disc rotor was scratching the carriers, otherwise no issues at all.
Vincereese
01-06-2023 09:14 AM
Kyle Langford
27
05-08-2019 07:54 PM
FlashRS
14-09-2015 12:36 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Quick Reply: Escort Mk6 Brake upgrade.
