idle control valve
Old 04-09-2007, 04:54 PM
ginner s2
ginner s2's Avatar
Default idle control valve
can someone plz tell me if it is located on the back of the inlet manifold and does it look like a bolt wiv a small pipe on the top.thanks
Old 04-09-2007, 06:03 PM
Moonie
Moonie's Avatar
If yours is still on standard Escort (k-jetronic) management it will not have an idle speed "control" valve.
There are two means of controling the idle speed (idle air by-pass) on standard management. From cold the auxillary air valve (circled in the picture below) will be fully open. This will allow extra air to by-pass the throttle to give fast idle for cold starting. As the engine warms up the valve closes and the idle speed will drop to the base idle speed.
The idle speed is then determined by the ammount of air that is allowed to by-pass the throttle butterfly via the idle speed control screw. This is located on the throttle body next to the throttle position switch.
mark94
10-10-2023 06:52 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: idle control valve
