CITROEN BERLINGO-PEUGEOT PARTNER
Old 31-08-2007, 09:58 AM
cozzfather
C.R.E.A.M.
cozzfather's Avatar
Default CITROEN BERLINGO-PEUGEOT PARTNER
I have a problem in that the door locks don't work properly.
sometimes the drivers door locks and unlocks but 99% of the time
the key just spins easy in the lock, the back door and passenger
are the same,the key does not look worn, any ideas?
Old 31-08-2007, 04:11 PM
peteh
peteh's Avatar
bttt as im just going to buy one, that dosen't seem to wana lock using the key fob (central locking)
Old 31-08-2007, 04:17 PM
Turboboy67
Turboboy67's Avatar
My Berlingo has the same problem on the passenger lock
My drivers lock is dodgy as well
Think its a common problem on them, you can get new locks on e-bay.
Old 31-08-2007, 04:28 PM
focusv8
focusv8's Avatar
Needs a new battery, had that on my current Partner.(went at about 75000)
Had that on my last Partner, It WAS the key. (went at about 125000)
Old 31-08-2007, 06:58 PM
peteh
peteh's Avatar
my mate who im buying it off changed the battery though think it maybe a conection in the key.
Old 31-08-2007, 07:10 PM
peteh
peteh's Avatar
all locks on ebay look like they don't do central locking
or can you just change the actual key part?
Old 31-08-2007, 07:53 PM
DazC
DazC's Avatar
The locks have platsic tumblers IIRC that wear the metal key. I had to get a new key for mine. Then I got rid of the piece of fucking shit. Now I'm back in a Shitroen Delinquent again!
Old 31-08-2007, 09:13 PM
Tank Mike
Tank Mike's Avatar
i worked at a van retal company. they are like that from brand new. its a safty thing so if someone puts a screw drive in the lock ect it just spins round.
you just have to make sure the key is pushed in firmly before you twist it because if the key is not all the way in the lock it will spin.
hope this helps
Old 31-08-2007, 09:38 PM
Dicko&Vacant
Dicko&Vacant's Avatar
my peugeot partner work van has the same problem with the back door pmsl you have to push the key all the way in while you lock or unlock it
Old 03-09-2007, 03:19 PM
cozzfather
C.R.E.A.M.
cozzfather's Avatar
if i pushed the key any further i would brake a world record for
moving a van with just a key.
the locks on this van are w@nk imo
i'm sure that changing the battery if you got central locking won't do it.
my one does not have c-l, apart from the W@NK locks its a great van
looks like it needs a new lock then
funny how the steering lock works perfect though
Old 03-09-2007, 03:28 PM
Paddy
Legend
Paddy's Avatar
I had a partner van a month or so ago and had to change the drivers lock. It was only about £40 trade from citroens so not the end of the world! An like you said, the key is fine it's just the poxy locks!
Great vans though!
RSBryden
06-09-2015 08:39 PM
frog
20
02-07-2005 11:18 AM
jr
01-10-2004 11:18 PM
Quick Reply: CITROEN BERLINGO-PEUGEOT PARTNER
