RS 2000 MK6 / escort gti mk6 rear disk conversion HELP ?
Old 27-06-2007, 12:05 AM
spi escort gti
spi escort gti's Avatar
Default RS 2000 MK6 / escort gti mk6 rear disk conversion HELP ?
Hi i have bean looking to put a rear disk conversion on my escort gti
now i have bean told that the rs2000 rear disk pads calipers and hup will swop over to go on mine is this true ?
1 more question is someone els has said that the 4x4 rs2000 will not fit my gti something about the 4x4 hass a hub and mine has a axel
so if im thinking right thier must be a rs 2000 2 wd witch also has the set up i want to put on the back of my gti
I AM CONFUSED WITH WHAT I CAN USE AND I CAN NOT USE AND WHAT
PARTS DO I NEED AND OF WHAT CAR
PLESES HELP
Old 27-06-2007, 07:10 AM
spi escort gti
CAN ANYONE HELP ?
Old 27-06-2007, 09:04 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
you cant use the 4x4 stuff.
you can use the 2wd stuff tho, but you will need the complete rear beam as the stub axles have a different bolt patter to mk6, unless you can find a mk6 rs2k rear brake setup.
if you can, you need
hubs/stub axles, discs callipers pads and handbrake cable.
if its all off a mk5 then you will need the rear beam aswell
HTH
Old 27-06-2007, 01:57 PM
spi escort gti
thanx alot mate is it a dear job and alot of work ?
Old 27-06-2007, 02:17 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
can get complete beams for around the £150 mark, hand brake cable is sub £20 iirc
pretty easy to change over too
Old 27-06-2007, 03:26 PM
Dangerous Malcolm..
Dangerous Malcolm..'s Avatar
If your GTI has ABS then you can't go the RS2000 route. If your car doesn't have ABS then it's a straight forward bolt on job. You'll need a MK6 RS2000 (non-ABS) handbrake cable and possibly (like I did) an upgraded master cylinder.
Some info HERE for the ABS conversion.
Old 27-06-2007, 11:12 PM
spi escort gti
oh god its never straight forward is it
MINE HAS ABS
and im haveing trouble finding a rs2k 2wd
found some on ebay they all asking £200 and they wont post so a caria be £45 i feal the back going to get a good kicking ha ha ha
anything els i need to no before i take this conversion on ?
Old 28-06-2007, 03:44 PM
Dangerous Malcolm..
There's always disc beams for sale on http://www.escortevolution.co.uk/for...db&showforum=6 , but I wouldn't personally go that way with an ABS equipped car. See how much a kit from Pumabuild would cost.
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
RsS2daz
14-08-2015 05:26 AM
sridgett
03-08-2015 07:26 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: RS 2000 MK6 / escort gti mk6 rear disk conversion HELP ?
