URGENT HELP NEEDED!!!!
Old 06-04-2007, 01:03 PM
AJcos
AJcos's Avatar
Default URGENT HELP NEEDED!!!!
My mate has just fitted a Bailey header tank to my brother's RS Focus and now when he gets to 4500RPM on boost, it hesitates.
Does anyone know why this could be happening?
It also has a collins powerchip installed but all was fine last night and i have tried disconnecting the chip and it was still the same.
PLEASE HELP!
Old 06-04-2007, 04:05 PM
FRS 3409
FRS 3409's Avatar
main coolant header tank or chargecooler tank?
check the coolant level in both to see if they are low. possibility of a lack of coolant in the chargecooler system could cause this.
ian
Old 06-04-2007, 04:38 PM
AJcos
AJcos's Avatar
Just the main coolant header tank.
Checked both levels and seem fine. Just re-fitted standard tank and still have the problem.
I have however found 2 fault codes but don't know what they are:-
9318
D262
Old 06-04-2007, 05:38 PM
FRS 3409
FRS 3409's Avatar
ive looked through a list of all the fault codes i have.
9318 is low battery voltage.
D262 is a missing SCP message. no idea what that may be though.
Old 06-04-2007, 07:17 PM
AJcos
AJcos's Avatar
Thanks for your help FRS 3409!!
The battery was low as its been stood for a while as my brother has been in Iraq so that explains that one.
I think the other one may have something to do with the powerchip that i disconnected.
I think i have now fixed it though--- it has a boost control valve fitted and i wound it down and it now doesn't hesitate although not as fast now for obvious reasons.
Think he's going to take it to Graham Goode to get it setup.
Thanks again for your help!!!!
Old 07-04-2007, 12:15 AM
FRS 3409
FRS 3409's Avatar
no problem
glad you found out the problem. sounds like its need of a good setup. im sure GGR will get it sorted out.
ian
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
col93saphcos
07-08-2015 03:21 PM
Quick Reply: URGENT HELP NEEDED!!!!
