small turbo 290 bhp?
Old 20-02-2007, 05:26 PM
rs cosworth
rs cosworth's Avatar
Default small turbo 290 bhp?
hi i have a small turbo escort cossie which i bought completely standard since then i have fitted the following items and was expecting about 290 bhp but i recently took it to a rr and only got 260 bhp and 296 lb ft is there anything else i need to add or should it be running around 290 bhp
intank uprated fuel pump
fuel regulator
chip
-31 actuater
full mongoose exhaust
k&n pannel filter
its running 1.25 bar dropping to 1.05 would it make a difference if it was holding 1.25
Old 20-02-2007, 06:12 PM
ECOS95
ECOS95's Avatar
Mine made 270 BHP & 280lb ft with just a panel filter & Mongoose on PE's rolling road.I've taken those figure with a pinch of salt to be honest but they put it down to holding over a bar after the over boost.If it held 1.25 it would be nearer the 300BHP I would of thought.
But you'll prob need a new turbo soon after.
Old 20-02-2007, 06:22 PM
kennyA
kennyA's Avatar
Hi
My car had all the cats cut out, powerchip, 1.5 bar boost dropping to about 1.3. In tank uprated fuel pump, 3.5bar fuel pressure.
289 ps
321Lb Ft. Suhe motorsport, Germany.
Have no idea how accurate the Dyno was.
Old 20-02-2007, 08:14 PM
AndyBrew
AndyBrew's Avatar
mine was 270hp/307lbs with chip/zaust/-31 actuator/fuel pump
Old 20-02-2007, 09:48 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
They should hold 1.3 bar mate, thats why your power is down.
What you need is a nice bolt on 350 conversion.
Old 20-02-2007, 10:20 PM
cos im worth it
On here to much!!
cos im worth it's Avatar
ST 350 horsies bolt on kit sounds Fantastic Stu.
Old 20-02-2007, 11:09 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
mine used to hold 1.2 bar made 300bhp 320lbft
Old 20-02-2007, 11:19 PM
Robski
Robski's Avatar
whens this gonna be available Stu? and a rough price
Old 21-02-2007, 03:09 AM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
When I took mine to PE 4 years ago it made 257bhp and its standard! They couldnt believe it and took 4 readings, said it might have a hybrid turbo
Old 21-02-2007, 07:13 AM
Most details are on this topic...
https://passionford.com/forum/viewtopic.php?t=241735
It will be upated as things progress..
Old 21-02-2007, 08:56 AM
Mr.Ford
Mr.Ford's Avatar
I've heard that more from other ST Escort's...
I think that they deliver more power because they have a overboost for a couple of seconds.
Old 21-02-2007, 08:03 PM
ECOS95
ECOS95's Avatar
As Cossie Lee said something is odd with the ST as mine isn't chipped either so shouldn't make anywhere near 270bhp.
They did mine 5 times, I was a nervous wreck
The setup of the rolling road seems to effect the results a hell of a lot as they could get figures for mine ranging from 280BHP to 250BHP.Mine was run by Chris who use to work @ PE doing the work.He's a knowlegable guy on RS's so u can imagine what an Optimistic RR operate could tell u !!!
Old 22-02-2007, 12:17 AM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
Does seem strange, I took mine for a RR de-tune, took off a faulty chip, they said it was the first Cossie they ever de-tuned!
Old 22-02-2007, 06:11 PM
ECOS95
ECOS95's Avatar
LOL
3i Jim
20-11-2015 05:12 AM
Matt Baxter
16-09-2015 08:30 PM
Cosnada
27-08-2015 09:15 AM
CrOwSoN15
18
22-08-2015 10:24 PM
IAN RS2k
18-08-2015 07:51 PM
Quick Reply: small turbo 290 bhp?
